Hi. Sorry if this all sounds basic but I’m new to haproxy and still going through the documentation while being thrown into the deep end.
Dockerized Haproxy version - haproxytech/haproxy-debian 2.9.5
The stick table.
backend table_track_ip
stick-table type string len 45 size 100k expire 300s store gpc0_rate(60s),gpc1_rate(10s),gpt(2),http_req_rate(10s),http_req_cnt,bytes_out_rate(1s),bytes_in_rate(1s)
And I have the following ACL
# slow if too many requests receive http 401 response codes in 60s
http-request deny deny_status 429 if { sc0_gpc0_rate gt 10}
And I am trying to convert the numeric 10 to use a variable based on a map file.
Reason being so I can change the value on the fly using the API without restarting the haproxy service and dropping any connections.
One example of what I have tried(and failed) since the I’m unable to get the syntax right.
http-request set-var(req.auth_temp_limit) str(map(/etc/haproxy/config.map, auth_failure_threshold, 10))
http-request set-var(req.limit_num) int(%[var(req.auth_temp_limit)])
http-request deny status 429 if { sc0_gpc0_rate gt var(req.limit_num) }
Is it even possible to chain it this way? I’m aware that these variables are all strings but is there a way to convert them to INT?
The config.map
#Rates and limits config used by haproxy logic
auth_failure_threshold 10
Can someone please point me in the right direction or indicate this is not possible or otehrwise.
p.s I have a whole bunch of other values to using map files and not just for sc0_gpc0_rate.
Thank you.
