Last year I followed this great tutorial, and I got openvpn, ssh, and some websites to work from a single 443 port.
Everything was working great until last week, when I upgraded my pfsense box from 2.4.3 to 2.4.4. It also upgraded the haproxy package from 1.5 to 1.8, and now haproxy does not proxy anything except for openvpn that still works.
Running the config through the config check says it is OK.
I tried to get some debug logging but nothing is sent to my syslog server (it was working before). And when I launch haproxy in debug mode with “-d”, I get the default log format instead of the tcp or http as defined in the config.
Is there any major changes in the config from 1.5 to 1.8?
My current configuration:
haproxy.cfg
# Generated on: 2018-10-04 00:12
maxconn 500
log log.example.com:514 local0 debug
uid 80
gid 80
nbproc 1
nbthread 1
hard-stop-after 15m
chroot /tmp/haproxy_chroot
log-send-hostname pfs
# Modern browser compatibility only as mentioned here:
# https://wiki.mozilla.org/Security/Server_Side_TLS
ssl-default-bind-ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!3DES:!MD5:!PSK
# Time-to-first-Byte (TTFB) value needs to be optimized based on
# the actual public certificate chain see
# https://www.igvita.com/2013/10/24
# /optimizing-tls-record-size-and-buffering-latency/
tune.ssl.maxrecord 1370
listen HAProxyLocalStats
stats admin if TRUE
stats show-legends
timeout client 5000
timeout server 5000
frontend WAN_HTTPS_offload-merged
bind 127.0.0.1:2043 name 127.0.0.1:2043 no-sslv3 no-tls-tickets no-tlsv10 no-tlsv11 ssl crt-list /var/etc/haproxy/WAN_HTTPS_offload.crt_list ca-file /var/etc/haproxy/clientca_WAN_HTTPS_offload.pem verify optional accept-proxy npn http/1.1
timeout client 7200000
# Remove headers that expose security-sensitive information.
rspidel ^Server:.*$
rspidel ^X-Powered-By:.*$
rspidel ^X-AspNet-Version:.*$
# add some security related headers
#rspadd Content-Security-Policy:\ default-src\ https:\ wss:\ data:\ \'unsafe-inline\'\ \'unsafe-eval\'
rspadd X-Frame-Options:\ SAMEORIGIN
rspadd X-Content-Type-Options:\ nosniff
rspadd X-Xss-Protection:\ 1;\ mode=block
capture request header X-Forwarded-For len 15
capture request header host len 50
capture request header X-Plex-Device-Name len 50
declare capture response len 32
http-response capture res.hdr(X-Forwarded-For) id 0
http-response capture res.hdr(host) id 1
acl aclsystem_ssl_c_used ssl_c_used
acl is_local src 192.168.10.0/24
acl CF_cert_ok ssl_c_verify 0
acl is_gateway src 192.168.10.254
acl is_local src 10.105.8.0/24
acl Plex_random var(txn.txnhost) -m str -i plex.example.com
acl Plex_random var(txn.txnhost) -m str -i plex.example.com:443
http-request add-header X-Forwarded-For %[req.hdr(CF-Connecting-IP)] if CF_cert_ok aclsystem_ssl_c_used
http-request add-header X-Forwarded-For %ci if is_local
use_backend plex_nas_ipvANY if Plex_random is_local !is_gateway
use_backend plex_nas_ipvANY if Plex_random CF_cert_ok aclsystem_ssl_c_used
default_backend None_backend_ipvANY
frontend WAN_SSLH-merged
bind 127.0.0.1:2022 name 127.0.0.1:2022 no-sslv3 ssl crt-list /var/etc/haproxy/WAN_SSLH.crt_list accept-proxy npn ssh/2.0
acl ssl_acl ssl_fc_npn -i ssh/2.0
acl proxmox ssl_fc_sni_reg prox.ssh.example.com
use_backend ssh_proxmox_b_ipvANY if proxmox ssl_acl
frontend WAN_443-merged
bind 192.168.10.100:443 name 192.168.10.100:443
timeout client 30000
tcp-request content accept if { req.ssl_hello_type 1 } or !{ req.ssl_hello_type 1 }
acl vpn_acl req.len 0
acl vpn_acl_1 req.ssl_hello_type 1
acl ssh_acl req_ssl_hello_type 1
acl ssh_acl_1 req_ssl_sni -m end -i ssh.example.com
acl https req.ssl_ver gt 0
acl offload_hostnames req.ssl_sni -i plex.example.com
acl proxy_hostnames req.ssl_sni -i bw.example.com
tcp-request content accept if { req.ssl_ver gt 0 }
use_backend OpenVPN_local_tun_b_ipvANY if !vpn_acl !vpn_acl_1
use_backend WAN_SSLH_b_ipvANY if ssh_acl ssh_acl_1
use_backend WAN_HTTPS_offload_b_ipvANY if https offload_hostnames
use_backend WAN_HTTPS_proxy_b_ipvANY if https proxy_hostnames
default_backend None_backend_ssl_ipvANY
frontend WAN_HTTPS_proxy-merged
bind 127.0.0.1:2044 name 127.0.0.1:2044 accept-proxy npn http/1.1
acl bitwarden req.ssl_sni -i bw.example.com
use_backend bitwarden_nas_ipvANY if bitwarden
frontend test
bind 192.168.10.100:80 name 192.168.10.100:80
id 101
timeout connect 30000
timeout server 30000
server none_backend_server 127.0.0.1:81 id 100
id 112
server plex_nas 192.168.20.2:32400 id 113 check inter 1000
id 114
retries 2
server proxmox_server 192.168.10.30:22 id 115
id 102
server none_backend_server 127.0.0.1:81 id 103
id 104
timeout server 7200000
retries 2
server OpenVPN_local_tun 192.168.10.100:100911 id 105
id 110
server WAN_SSLH 127.0.0.1:2022 id 111 ssl verify none send-proxy
id 108
server WAN_HTTPS_offload 127.0.0.1:2043 id 109 ssl verify none send-proxy
id 116
server WAN_HTTPS_proxy 127.0.0.1:2044 id 117 ssl verify none send-proxy
id 118
server bitwarden_nas_server 192.168.20.2:8091 id 119 ssl check inter 1000 verify none
Does anyone know if there are any changes that need to be done so that this config can work for 1.8?
