Configuration help challenge HTTP-01 ACME
Hi
I am asking for your help to configure my HAProxy configuration file “version 2.8.5-1~bpo12+1 2023/12/09”
I have two services that use the Acme HTTP-01 challenge and all the others use the DNS-01 challenge. With the latter (DNS-01), the certificates are renewed without problem, I tried to follow this thread for HTTP-01 without success. ACME Challenge Passthrough
Here is my HAProxy config, I left the domains for which the renewal fails:
Global settings
log /dev/log local6 notice
log /dev/log local5 info
maxconn 100000
pidfile /run/haproxy.pid
stats socket /var/run/haproxy/admin.sock mode 777 level admin
dedicated stats page
bind :22222
stats hide-version
stats uri /stats
stats realm HAProxy-Statistics
stats auth LOGIN:SECRET
stats refresh 30s
stats admin if TRUE
Frontend to redirect HTTP to HTTPS with code 301
frontend http-redirect
bind :80 v4v6
http-request redirect scheme https code 301
frontend main_https_listen
bind :443 v4v6
Common HAProxy nodes configuration
ACLs
acl acl_mailcowdatanetwork req.ssl_sni -i mail.example1.cloud www.mail.example1.cloud
acl acl_mailcowboubou req.ssl_sni -i mail.example2.me www.mail.example2.me
Conditions
use_backend backend_mailcowdatanetwork if acl_mailcowdatanetwork
use_backend backend_mailcowboubou if acl_mailcowboubou
Backends
description MAILCOW DATANETWORK
option ssl-hello-chk
server server_mailcowdatanetwork 192.168.1.7:443
description MAILCOW BOUBOU
server server_mailcowboubou 192.168.1.7:443
Thanks for your help
Well, I suggest you post the configuration that you tried based on that thread.
The configuration you posted contains none of it.
sorry for the late response, I was far from home for work.
Here is the configuration that I am trying to test to pass the acmé HTTP-01 challenge, I would like mail.boubou.me and mail.datanetwork.cloud to be able to pass the acmé HTTP-01 challenge, for everything else I use the challenge DNS-01, but unfortunately I cannot run it with Mailcow (self-hosted mail solution) and the developers do not intend to do so at the moment because the workload would be too heavy. and for the moment every 3 months I have to redirect port 80 and 443 directly on the mail server to renew the certificates.
# Global settings
    user                haproxy
    group               haproxy
    maxconn             100000
    mode                 tcp
    option               tcplog
    log                  global
    option               dontlognull
# dedicated stats page
    bind :22222
    stats hide-version
    stats uri            /stats
    stats auth           login:Password
    stats refresh        30s
#    stats admin if TRUE
# Front end Acme Challenge
frontend datanetwork.cloud:80
# Check for Acme Challange and validate url
    acl test_acme                          path_beg /.well-known/acme-challenge/
    acl mailcowdatanetwork_host hdr(host)  -i mail.datanetwork.cloud
    acl mailcowboubou_host hdr(host)       -i mail.boubou.me
# If no Acme Challenge redirect HTTPS
    redirect scheme https code 301 if !test_acme
# On Acme Challenge forward :80 to backend server
    use_backend le_mailcowdatanetwork_backend   if test_acme mailcowdatanetwork_host
    use_backend le_mailcowboubou_backend        if test_acme mailcowboubou_host
# frontend normal https traffic to valid urls
frontend datanetwork.cloud:443
  bind   *:443
  mode   tcp
  tcp-request inspect-delay 10s
  use_backend backend_mailcowdatanetwork   if { req.ssl_sni -m end   mail.datanetwork.cloud }
frontend boubou.me:443
  bind   *:443
  mode   tcp
  use_backend backend_mailcowboubou   if { req.ssl_sni -m end   mail.boubou.me }
# Renew certificate nextcloud server
  server letsencrypt_mailcowdatanetwork_server 192.168.1.7:80 check
  server letsencrypt_mailcowboubou_server 192.168.1.7:80 check
# Frontend to redirect HTTP to HTTPS with code 301
    bind :80 v4v6
    bind :443 v4v6
    mode                tcp
    option              tcplog
    log                 global
# Common HAProxy nodes configuration
# ACLs
acl acl_nextcloud               req.ssl_sni -i xxxxxxxxxx.datanetwork.cloud 	www.xxxxxxx.datanetwork.cloud
acl acl_ncs                     req.ssl_sni -i xxx.datanetwork.cloud 		www.xxxxx.datanetwork.cloud
acl acl_phpnextcloud            req.ssl_sni -i xxxxxxx.datanetwork.cloud 	www.xxxxxxxx.datanetwork.cloud
acl acl_mailcowdatanetwork      req.ssl_sni -i mail.datanetwork.cloud 		www.mail.datanetwork.cloud
acl acl_mailcowboubou           req.ssl_sni -i mail.boubou.me 			www.mail.boubou.me
acl acl_freebox                 req.ssl_sni -i xxxxxxx.datanetwork.cloud 	www.xxxxxx.datanetwork.cloud
acl acl_plex                    req.ssl_sni -i xxxxxxx.datanetwork.cloud 		www.xxxxxx.datanetwork.cloud
acl acl_tautulli                req.ssl_sni -i xxxxxxx.datanetwork.cloud 	www.xxxxxxx.datanetwork.cloud
acl acl_proxy                   req.ssl_sni -i xxxxxxxx.datanetwork.cloud 		www.xxxxxx.datanetwork.cloud
acl acl_proxystat               req.ssl_sni -i xxxxxxxxxxx.datanetwork.cloud 	www.xxxxxx.datanetwork.cloud
acl acl_lenovo                  req.ssl_sni -i xxxxxx.datanetwork.cloud 	www.xxxxxx.datanetwork.cloud
acl acl_mx                      req.ssl_sni -i xxxx.datanetwork.cloud 		www.xxxxxx.datanetwork.cloud
acl acl_nas                     req.ssl_sni -i xxxxxx.datanetwork.cloud 		www.xxxxxxx.datanetwork.cloud
acl acl_readynas                req.ssl_sni -i xxxxxxx.datanetwork.cloud 	www.xxxxx.datanetwork.cloud
acl acl_blog                    req.ssl_sni -i xxxxx.boubou.me			www.xxxxxxx.boubou.me
# Conditions
use_backend backend_nextcloud if acl_nextcloud
use_backend backend_ncs if acl_ncs
use_backend backend_phpnextcloud if acl_phpnextcloud
use_backend backend_freebox if acl_freebox
use_backend backend_plex if acl_plex
use_backend backend_tautulli if acl_tautulli
use_backend backend_proxy if acl_proxy
use_backend backend_proxystat if acl_proxystat
use_backend backend_lenovo if acl_lenovo
use_backend backend_mx if acl_mx
use_backend backend_nas if acl_nas
use_backend backend_readynas if acl_readynas
use_backend backend_blog if acl_blog
# Backends
# APP 1 NEXTCLOUD
    description NEXTCLOUD
    server server_nextcloud 192.168.1.6:443 check send-proxy
# APP 2 NCS NEXTCLOUD STATS
backend backend_ncs
    description NCS NEXTCLOUD STATS
    server server_ncs 192.168.1.6:444 check send-proxy-v2
# APP 3 PHP NCS NEXTCLOUD
    description PHP NEXTCLOUD
    server server_phpnextcloud 192.168.1.6:444 check send-proxy-v2
# APP 4 MAILCOW DATANETWORK
    server server_mailcowdatanetwork 192.168.1.7:443 check
# APP 5 MAILCOW BOUBOU
    server server_mailcowboubou 192.168.1.7:443 check
# APP 6 FREEBOX DELTA
    description FREEBOX DELTA
    server server_freebox 127.0.0.1:444 check send-proxy-v2
# APP 7 PLEX
    description PLEX
    server server_plex 127.0.0.1:444 check send-proxy-v2
# APP 8 TAUTULLI
    description TAUTULLI
    server server_tautulli 127.0.0.1:444 check send-proxy-v2
# APP 9 PROXY NETDATA
    description PROXY NETDATA
    server server_proxy 127.0.0.1:444 check send-proxy-v2
# APP 10 PROXY STATS
    description HAPROXY STATS
    server server_proxystat 127.0.0.1:444 check send-proxy-v2
# APP 11 NETDATA LENOVO TS-150
    description TS150 NETDATA
    server server_lenovo 127.0.0.1:444 check send-proxy-v2
# APP 12 MX NETDATA
backend backend_mx
    description MX NETDATA
    server server_mx 127.0.0.1:444 check send-proxy-v2
# APP 13 NAS NETDATA
backend backend_nas
    description NAS NETDATA
    server server_nas 127.0.0.1:444 check send-proxy-v2
# APP 14 READYNAS
    description READYNAS
    server server_readynas 127.0.0.1:444 check send-proxy-v2
# APP 15 BLOG
    description BLOG
    server server_blog 192.168.1.6:444 check send-proxy-v2
I don’t see anything wrong with it. Check your logs and confirm that you are passing the request through.
Hi
I managed to renew the let’s encrypt certificates, for this I deleted the following lines:
and I had problems with the autodiscover and autoconfig verification during the renewal, so I added the following lines:
    use_backend le_mailcowdatanetworkautoconfig_backend     if test_acme mailcowdatanetworkautoconfig_host
    use_backend le_mailcowboubouautoconfig_backend          if test_acme mailcowboubouautoconfig_host
    use_backend le_mailcowdatanetworkautodiscover_backend   if test_acme mailcowdatanetworkautodiscover_host
    use_backend le_mailcowboubouautodiscover_backend        if test_acme mailcowboubouautodiscover_host
  server letsencrypt_mailcowdatanetworkautoconfig_server 192.168.1.7:80 check
  server letsencrypt_mailcowboubouautoconfig_server 192.168.1.7:80 check
  server letsencrypt_mailcowdatanetworkautodiscover_server 192.168.1.7:80 check
  server letsencrypt_mailcowbouboudiscover_server 192.168.1.7:80 check
and now the renewal or creation of certificates works with the HTTP-01 challenge,
Here is the final configuration file, if you see any errors, thank you in advance for telling me.
# Global settings
    user                haproxy
    group               haproxy
    maxconn             100000
    mode                 tcp
    option               tcplog
    log                  global
    option               dontlognull
    bind :22222
    stats hide-version
    stats uri            /stats
    stats auth           loguin:@XXXXXXX
    stats refresh        30s
    bind :80 v4v6
frontend boubou.me:80
    bind :80 v4v6
# Check for Acme Challenge and validate url
    acl mailcowdatanetworkautoconfig_host hdr(host)    -i autoconfig.datanetwork.cloud
    acl mailcowboubouautoconfig_host hdr(host)         -i autoconfig.boubou.me
    acl mailcowdatanetworkautodiscover_host hdr(host)  -i autodiscover.datanetwork.cloud
    acl mailcowboubouautodiscover_host hdr(host)       -i autodiscover.boubou.me
# Renew certificate Mailcow server
    bind :443 v4v6
    mode                tcp
    option              tcplog
    log                 global
# ACLs
acl acl_nextcloud               req.ssl_sni -i XXXXXX.datanetwork.cloud 	www.nextcloud.datanetwork.cloud
acl acl_ncs                     req.ssl_sni -i XXXX.datanetwork.cloud 		www.ncs.datanetwork.cloud
acl acl_phpnextcloud            req.ssl_sni -i XXXX.datanetwork.cloud 	www.phpncs.datanetwork.cloud
acl acl_freebox                 req.ssl_sni -i XXXX.datanetwork.cloud 	www.freebox.datanetwork.cloud
acl acl_plex                    req.ssl_sni -i XXXX.datanetwork.cloud 		www.plex.datanetwork.cloud
acl acl_tautulli                req.ssl_sni -i XXXX.datanetwork.cloud 	www.tautulli.datanetwork.cloud
acl acl_proxy                   req.ssl_sni -i XXXX.datanetwork.cloud 		www.proxy.datanetwork.cloud
acl acl_proxystat               req.ssl_sni -i XXXXt.datanetwork.cloud 	www.proxystat.datanetwork.cloud
acl acl_lenovo                  req.ssl_sni -i XXXX.datanetwork.cloud 	www.lenovo.datanetwork.cloud
acl acl_mx                      req.ssl_sni -i XXXX.datanetwork.cloud 		www.mx.datanetwork.cloud
acl acl_nas                     req.ssl_sni -i XXXX.datanetwork.cloud 		www.nas.datanetwork.cloud
acl acl_readynas                req.ssl_sni -i XXXX.datanetwork.cloud 	www.readynas.datanetwork.cloud
acl acl_blog                    req.ssl_sni -i XXXX.boubou.me			www.blog.boubou.me
# Conditions
# Backends
# APP 1 NEXTCLOUD
    server server_nextcloud 192.168.1.5:443 check send-proxy
backend backend_ncs
    server server_ncs 192.168.1.5:444 check send-proxy-v2
    server server_phpnextcloud 192.168.1.5:444 check send-proxy-v2
# APP 7 PLEX
    description PLEX
# APP 8 TAUTULLI
# APP 12 MX NETDATA
backend backend_mx
backend backend_nas
# APP 14 READYNAS
# APP 15 BLOG
    description BLOG
    server server_blog 192.168.1.5:444 check send-proxy-v2
And here is the Acme log file
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Waiting for Docker API...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Docker API OK
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Waiting for Postfix...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Postfix OK
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Waiting for Dovecot...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Dovecot OK
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Restoring mailcow snake-oil certificates and restarting script...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Waiting for database...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Database OK
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Waiting for Nginx...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Nginx OK
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Waiting for resolver...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Resolver OK
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Waiting for domain table...
mailcowdockerized-acme-mailcow-1  | OK
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:00 CET 2024 - Initializing, please wait...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:01 CET 2024 - Generating missing domain private rsa key...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:05 CET 2024 - Generating missing Lets Encrypt account key...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:05 CET 2024 - Valid email address, using XXXXX@XXXXX.XX for registration
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:08 CET 2024 - Detecting IP addresses...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - OK: XX.XX.X.XX, XXXX:e0a:831:7680:XXXX:6fff:fe32:XXXX
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Found AAAA record for autodiscover.boubou.me: XXXX:e0a:831:7680:baac:6fff:fe32:XXXX - skipping A record check
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Confirmed AAAA record with IP XXXX:0e0a:0831:7680:baac:6fff:fe32:XXXX
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Found AAAA record for autoconfig.boubou.me: XXXX:e0a:831:7680:baac:6fff:fe32:XXXX - skipping A record check
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Confirmed AAAA record with IP 2a01:0e0a:0831:7680:baac:6fff:fe32:5e5e
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Found AAAA record for autodiscover.datanetwork.cloud:XXXX:e0a:831:7680:baac:6fff:fe32:XXXX - skipping A record check
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Found AAAA record for autoconfig.datanetwork.cloud:XXXX:e0a:831:7680:baac:6fff:fe32:XXXX - skipping A record check
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Found AAAA record for mail.datanetwork.cloud:XXXX:e0a:831:7680:baac:6fff:fe32:XXXX - skipping A record check
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Found AAAA record for mail.boubou.me: XXXX:e0a:831:7680:baac:6fff:fe32:XXXX- skipping A record check
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Certificate /var/lib/acme/mail.datanetwork.cloud/cert.pem missing or changed domains 'mail.datanetwork.cloud mail.boubou.me' - start obtaining
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Copying shared private key for this certificate...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Checking resolver...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Resolver OK
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:09 CET 2024 - Using command acme-tiny  --contact mailto:XXXX@XXXX.XX --account-key /var/lib/acme/acme/account.pem --disable-check --csr /var/lib/acme/mail.datanetwork.cloud/acme.csr --acme-dir /var/www/acme/
mailcowdockerized-acme-mailcow-1  | Parsing account key...
mailcowdockerized-acme-mailcow-1  | Parsing CSR...
mailcowdockerized-acme-mailcow-1  | Found domains: mail.boubou.me, mail.datanetwork.cloud
mailcowdockerized-acme-mailcow-1  | Getting directory...
mailcowdockerized-acme-mailcow-1  | Directory found!
mailcowdockerized-acme-mailcow-1  | Registering account...
mailcowdockerized-acme-mailcow-1  | Registered! Account ID: https://acme-v02.api.letsencrypt.org/acme/acct/XXXXXX
mailcowdockerized-acme-mailcow-1  | Updated contact details:
mailcowdockerized-acme-mailcow-1  | mailto:XXXX@XXXX.XXX
mailcowdockerized-acme-mailcow-1  | Creating new order...
mailcowdockerized-acme-mailcow-1  | Order created!
mailcowdockerized-acme-mailcow-1  | Verifying mail.boubou.me...
mailcowdockerized-acme-mailcow-1  | mail.boubou.me verified!
mailcowdockerized-acme-mailcow-1  | Verifying mail.datanetwork.cloud...
mailcowdockerized-acme-mailcow-1  | mail.datanetwork.cloud verified!
mailcowdockerized-acme-mailcow-1  | Signing certificate...
mailcowdockerized-acme-mailcow-1  | Certificate signed!
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:49 CET 2024 - Deploying certificate /var/lib/acme/mail.datanetwork.cloud/cert.pem...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:49 CET 2024 - Verified hashes.
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:49 CET 2024 - Certificate successfully obtained
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:49 CET 2024 - Certificate /var/lib/acme/autodiscover.boubou.me/cert.pem missing or changed domains 'autodiscover.boubou.me autoconfig.boubou.me' - start obtaining
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:49 CET 2024 - Copying shared private key for this certificate...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:49 CET 2024 - Checking resolver...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:49 CET 2024 - Resolver OK
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:20:49 CET 2024 - Using command acme-tiny   --account-key /var/lib/acme/acme/account.pem --disable-check --csr /var/lib/acme/autodiscover.boubou.me/acme.csr --acme-dir /var/www/acme/
mailcowdockerized-acme-mailcow-1  | Found domains: autodiscover.boubou.me, autoconfig.boubou.me
mailcowdockerized-acme-mailcow-1  | Already registered! Account ID: https://acme-v02.api.letsencrypt.org/acme/acct/XXXXXXX
mailcowdockerized-acme-mailcow-1  | Verifying autoconfig.boubou.me...
mailcowdockerized-acme-mailcow-1  | autoconfig.boubou.me verified!
mailcowdockerized-acme-mailcow-1  | Verifying autodiscover.boubou.me...
mailcowdockerized-acme-mailcow-1  | autodiscover.boubou.me verified!
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:21:32 CET 2024 - Deploying certificate /var/lib/acme/autodiscover.boubou.me/cert.pem...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:21:32 CET 2024 - Verified hashes.
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:21:32 CET 2024 - Certificate successfully obtained
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:21:32 CET 2024 - Certificate /var/lib/acme/autodiscover.datanetwork.cloud/cert.pem missing or changed domains 'autodiscover.datanetwork.cloud autoconfig.datanetwork.cloud' - start obtaining
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:21:32 CET 2024 - Copying shared private key for this certificate...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:21:32 CET 2024 - Checking resolver...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:21:32 CET 2024 - Resolver OK
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:21:32 CET 2024 - Using command acme-tiny   --account-key /var/lib/acme/acme/account.pem --disable-check --csr /var/lib/acme/autodiscover.datanetwork.cloud/acme.csr --acme-dir /var/www/acme/
mailcowdockerized-acme-mailcow-1  | Found domains: autoconfig.datanetwork.cloud, autodiscover.datanetwork.cloud
mailcowdockerized-acme-mailcow-1  | Verifying autoconfig.datanetwork.cloud...
mailcowdockerized-acme-mailcow-1  | autoconfig.datanetwork.cloud verified!
mailcowdockerized-acme-mailcow-1  | Verifying autodiscover.datanetwork.cloud...
mailcowdockerized-acme-mailcow-1  | autodiscover.datanetwork.cloud verified!
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:22:12 CET 2024 - Deploying certificate /var/lib/acme/autodiscover.datanetwork.cloud/cert.pem...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:22:12 CET 2024 - Verified hashes.
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:22:12 CET 2024 - Certificate successfully obtained
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:22:12 CET 2024 - Reloading or restarting services... (1)
mailcowdockerized-acme-mailcow-1  | Restarting 4f87d08b4efdd788fa9dac8de8f6d5d884dd6de2c79b0133a80abb1XXXXb1c5...
mailcowdockerized-acme-mailcow-1  | command completed successfully
mailcowdockerized-acme-mailcow-1  | Restarting 88ec0e1a93d50f989fafce44aba9e52810679e0a1bd9133XXXXXe39289d0...
mailcowdockerized-acme-mailcow-1  | Restarting 361f54d3f3c09bd221644c944d8fc513d59512a570e56XXXX9acb9dac8c737...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:22:22 CET 2024 - Waiting for containers to settle...
mailcowdockerized-acme-mailcow-1  | Sat Feb 24 17:22:32 CET 2024 - Certificates successfully requested and renewed where required, sleeping one day
