Connection churn issue
I am facing connection churn issue when I am using keep-alive and http-tunnel introduces un-even load balancing at the backend.
Should I use below -
optiuon http-server-close
http-reuse always
You have to provide more details for us to be able to give you a recommendation. Start with providing the rest of your configuration, especially related to load-balancing.
Here is my current setup
stats socket /var/run/haproxy.sock mode 600 level admin
maxconn 20000
option http-tunnel
option  redispatch
    option  forwardfor
option httpclose
    timeout  connect 10000
    timeout  client  10000
    timeout  server  10000
internal statistics
bind XXXXXXXXXXXX:9999
stats uri /haproxy?stats
frontend instances
frontend test_ha
bind XXXXXXXXXXXX:8090
default_backend test_back
backend instances
backend test_back
#option http-tunnel
http-reuse always
option allbackups
option tcp-smart-connect
option prefer-last-server
server test1 XXXXXXXXXXXX:80 check port 80
server test2 XXXXXXXXXXXX.:80 check port 80
server test3 XXXXXXXXXXXX:80 check port 80
server test4 XXXXXXXXXXXX:80 check port 80
Our requirement is to achieve even load balancing with a minimal number of RST at the backend. we are able to achieve it with http-tunnel option but that doesn’t honor load balancing when traffic is very high.
Then you cannot use roundrobin. Replace balance roundrobin with balance leastconn and if that is not enough, remove option prefer-last-server.
