I am trying to create an IPv4 to IPv6 proxy of sorts.
I have a VPS that has both IPv4 and IPv6 connectivity, and a backend that has IPv6 only.
Hosts replaced with example.org because I don’t feel like adding more background noise to my VPS or my other hosts.
docker compose on VPS:
services:
haproxy:
image: haproxytech/haproxy-alpine:latest
volumes:
- ./config:/usr/local/etc/haproxy/
network_mode: host
restart: unless-stopped
haproxy config:
timeout client 30s
timeout connect 4s
timeout server 30s
frontend listener
bind 10.0.0.156:443 #Internal VPS v4 address, maps to public v4 address
log stdout format raw daemon debug
tcp-request inspect-delay 1s
use_backend my_v6_host if { req_ssl_sni -i v6.example.org }
backend my_v6_host
server my_v6 v6.example.org:443 #/etc/hosts entry so I get the correct IP
option ssl-hello-chk
Testing from another machine - I had this working, I am wondering if it’s an issue of ordering in the config
curl.exe --resolve example.org:443:<public ipv4 of VPS> -k -vv -H "Host: example.org" https://example.org
18:20:18.236000 [0-0] * [HTTPS-CONNECT] connect, init
18:20:18.236000 [0-0] * Trying <v4 address of VPS>:443...
18:20:18.236000 [0-0] * [HTTPS-CONNECT] connect -> 0, done=0
18:20:18.236000 [0-0] * [HTTPS-CONNECT] adjust_pollset -> 1 socks
18:20:18.268000 [0-0] * ALPN: curl offers http/1.1
18:20:18.268000 [0-0] * TLSv1.3 (OUT), TLS handshake, Client hello (1):
18:20:18.268000 [0-0] * [HTTPS-CONNECT] connect -> 0, done=0
18:20:18.274000 [0-0] * [HTTPS-CONNECT] adjust_pollset -> 1 socks
18:20:18.280000 [0-0] * TLS connect error: error:00000000:lib(0):func(0):reason(0)
18:20:18.282000 [0-0] * LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to home.baxter.works:443
18:20:18.284000 [0-0] * [HTTPS-CONNECT] connect, all failed
18:20:18.286000 [0-0] * [HTTPS-CONNECT] connect -> 35, done=0
18:20:18.286000 [0-0] * closing connection #0
18:20:18.286000 [0-0] * [HTTPS-CONNECT] close
18:20:18.286000 [0-0] * [SETUP] close
18:20:18.286000 [0-0] * [SETUP] destroy
18:20:18.286000 [0-0] * [HTTPS-CONNECT] destroy
curl: (35) TLS connect error: error:00000000:lib(0):func(0):reason(0)
