Counter issues on 1.8.29
We’re using some restrictions like this:
stick-table type ip size 1m expire 30s store gpc0,conn_cur,conn_rate(3s),http_req_rate(10s),http_err_rate(30s) peers mypeers
# Reject over 50 concurrent connections per ip
tcp-request connection reject if { src_conn_cur ge 50 }
# Reject if more than 30 connections in 3 seconds
tcp-request connection reject if { src_conn_rate ge 30 }
# Reject more than 30 http requests in 10 seconds
tcp-request content reject if { src_http_req_rate ge 30 }
# Reject if more than 10 http errors in 30 seconds
tcp-request content reject if { src_http_err_rate ge 10 }
While they’re not terribly nice, they used to work as expected. After upgrading to 1.8.29 we do get connection reset at normal browsing, a few requests from a browser, definitely none of the above limits being hit. There are two proxies in peering.
Downgraded back to 1.8.28 restored the expected behaviour. There was no configuration change.
Thanks,
Victor
Yes, this is a known a new regression in the latest bugfix releases, patches have been posted and committed to 2.2 tree, other backports will follow:
https://www.mail-archive.com/haproxy@formilux.org/msg40020.html
All supported stable branches now have the fix.
You can git clone from the 1.8 branch, or get get the backported patches here manually:
http://git.haproxy.org/?p=haproxy-1.8.git;a=patch;h=bfba403a925c954daf6f43a3239429044681316b
http://git.haproxy.org/?p=haproxy-1.8.git;a=patch;h=491b86ed0acdb4f3a1673f9357240176da930548
(both are necessary). Tomorrows 1.8 snapshot haproxy-ss-20210325.tar.gz will also contain those fixes.
I’ve also filed a tracking issue at github:
Thanks Lukas, 1.8.29 plus the two patches is working fine.
Do you happen to have an estimate as to when the fixes might be available as a new release for the 2.2 version (as 2.2.12)?
Asking because I’m using prebuilt packages and can’t easily patch anything manually.
https://www.mail-archive.com/haproxy@formilux.org/msg40050.html
2.2.12: probably early next week to still give some time for last issues
to be reported.
An alternative is 2.3.8, although that is not a LTS branch.
