I have enabled stats for gui, checking session for front-end, the count of “curr session” is always high. Meaning when I just use a single website URL(http://haproxywebserver: haproxy listen port/shprd/signon.html)from IE browser , instead of displaying 1, it display 5
Any reason? I am using mode http.
Due to that, I am unable to get the correct count of HTTP connections from different user machine and browser.
Thanks much for your response, I will check on this and revert.
I also have another query on the same topic, when sign out occurs (cookie will become invalid when sign out occurs) from application, log out URL will be something /?cmd=logout .
Even when session/connection is logged out, the current session, still shows as 1, when I close the browser completely, then curr session becomes 0.
Is there any timeout parameter for the URL having log out string, so that I can force haproxy to release the http connection having logout in the URL without need to close the browser.
