I have a case where some requests gets return a 400 error from haproxy, others not. The requests themselves look very similar.
I would like to find out what is the reason for the 400 error. Can you please suggest the best way to do this?
What I have tried so far is the following:
This command suggested by others, outputs 0 events.
echo “show errors” | socat stdio unix-connect:/run/haproxy/admin.sock
Total events captured on [31/Aug/2023:11:29:22.602] : 0
The config contains: stats socket /run/haproxy/admin.sock mode 600 level admin
I have tried to increase the logging level. But the change here does not increase the amount of detail in the log file.
log /dev/log local0 info
log /dev/log local1 debug
frontend and backend are using log global
Many thanks ![]()
HAProxy version 2.8.1-1~bpo11+1 2023/07/03 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2028.
Known bugs: http://www.haproxy.org/bugs/bugs-2.8.1.html
Running on: Linux 5.10.0-19-amd64 #1 SMP Debian 5.10.149-2 (2022-10-21) x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wall -Wextra -Wundef -Wdeclaration-after-statement -Wfatal-errors -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wno-string-plus-int -Wno-atomic-alignment
OPTIONS = USE_OPENSSL=1 USE_LUA=1 USE_SLZ=1 USE_SYSTEMD=1 USE_PROMEX=1 USE_PCRE2=1 USE_PCRE2_JIT=1
Feature list : -51DEGREES +ACCEPT4 +BACKTRACE -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL -ENGINE +EPOLL -EVPORTS +GETADDRINFO -KQUEUE -LIBATOMIC +LIBCRYPT +LINUX_SPLICE +LINUX_TPROXY +LUA +MATH -MEMORY_PROFILING +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL -OPENSSL_WOLFSSL -OT -PCRE +PCRE2 +PCRE2_JIT -PCRE_JIT +POLL +PRCTL -PROCCTL +PROMEX -PTHREAD_EMULATION -QUIC +RT +SHM_OPEN +SLZ +SSL -STATIC_PCRE -STATIC_PCRE2 +SYSTEMD +TFO +THREAD +THREAD_DUMP +TPROXY -WURFL -ZLIB
Built with multi-threading support (MAX_TGROUPS=16, MAX_THREADS=256, default=4).
Built with OpenSSL version : OpenSSL 1.1.1n 15 Mar 2022
Running on OpenSSL version : OpenSSL 1.1.1n 15 Mar 2022
: mode=HTTP side=FE|BE mux=H1 flags=HTX
: mode=TCP side=FE|BE mux=PASS flags=
[BWLIM] bwlim-in
[BWLIM] bwlim-out
[FCGI] fcgi-app
