Delay all Database transactions with HAProxy
I am trying to simulate a delay between my applications and my postgres db by relaying all tcp messaging via my haproxy. this is my config
  timeout client 10s
  timeout server 10s
  timeout check 5s
frontend postgresDB
  bind *:5432
  tcp-request inspect-delay 5000ms
  tcp-request content accept if WAIT_END
  default_backend postgresDB
backend postgresDB
  server pdb 172.18.29.133:5432  check inter 5s rise 2 fall 3
It works very well with the initial connection but once the connection is established then there is no delay on any db transactions. Unfortunately my apps make their connection to the database when they start up and then maintain that connection. Is there a way HAproxy can be configured to delay all communication within the session as well as the initial connection?
