Using version 2.6.18
I am updating a working haproxy configuration to be able to handle backend servers not being up yet at the time haproxy is starting. It’s a docker container running in kubernetes, so the resolve.conf file is kubernetes generated, if that’s relevant.
Following all the documentation, I’ve updated to use init-addr none and added a resolver with parse-resolve-conf and added healthchecks, however, I get 503’s.
I was under the impression libc and a resolver with parse-resolve-conf would both be using the local resolver, why might I be getting different results?
Here’s a sanitized version of the config I’m using:
log stdout local0 warning
maxconn 5000
spread-checks 5
resolvers dns
parse-resolv-conf
accepted_payload_size 8192
option forwardfor except 127.0.0.1/8
option abortonclose
retries 1
timeout client 10m
timeout server 10m
timeout connect 4s
timeout http-keep-alive 20s
default-server check inter 30s slowstart 10s rise 1 fall 60 maxconn 500 weight 100 resolvers dns init-addr none
...(omitting front end config)
backend egbackend
server egbackend egbackend-dev-<redacted>.<redacted>.svc:8081
