not sure if this belongs to this section (Site Feedback), but I haven’t found any that would be more suitable
At HAProxy version 2.6.2-30 - Configuration Manual pretty much all opening (or rather 1st on the line) single quote characters in any examples are shown as ' instead of '
Examples:
2.4. Conditional blocks
.diag "WTA/2021-05-07: replace 'redirect' with 'return' after switch to 2.4"
7.3.1. Converters
regsub(<regex>,<subst>[,<flags>])
http-request set-header x-path "%[hdr(x-path),regsub('/+','/','g')]"
http-request set-header x-query "%[query,regsub([?;&]*,'')]"
http-request redirect location %[url,'regsub("(foo|bar)([0-9]+)?","\2\1",i)']
etc (just search for the ' string)
Compare that with the text version of the doc http://www.haproxy.org/download/2.6/doc/configuration.txt where no such issue can be seen.
This also affects older doc versions.
Can this be fixed so it wouldn’t be confusing?
