Title : Reference Manual for version 1.9
Item : Lua reference manual in HTML
Explain : open the link will get “404 Not Found” message
So this a link on haproxy.org @willy
In the documentation section, LUA reference manual points to:
http://www.arpalert.org/src/haproxy-lua-api/1.9/index.html
While the correct link would be:
http://www.arpalert.org/src/haproxy-lua-api/1.9dev/index.html
Also all links in doc/lua.txt always point to 1.6, even in 1.7+ releases.
[sending it again via the web interface]
now fixed both on the site and in sources + marked for backporting. Thanks Lukas!
