Domain base routing
Hi All,
we are trying that domain base routing in haproxy,in my backend server we are running 3 application. but when hit my url it navigate to only onethe domain.
Please find the below file haproxy configuration file.
    log-format "%ci %f %b %ST %HM %HU"
frontend http_front
#whitelist hosts
acl is_host1 hdr(host) -i portal.xxxx.com
acl is_host2 hdr(host) -i api.xxxxx.com
acl is_host3 hdr(host) -i skooner.xxxxxx.com
http-request redirect scheme https if is_host1
http-request redirect scheme https if is_host2
http-request redirect scheme https if is_host3
#letsencrypt
acl letsencrypt_acl path_beg /.well-known/acme-challenge/
use_backend letsencrypt_back if letsencrypt_acl
#all unmatched hosts
default_backend deny_back
frontend https_front
bind *:443 ssl crt /etc/haproxy/certs/
#whitelist hosts
acl is_host2 hdr(host) -i api.xxxx.com
acl is_host3 hdr(host) -i skooner.xxxx.com
#apps
use_backend https_back if is_host1
use_backend https_back if is_host2
use_backend https_back if is_host3
#websocket
acl is_websocket hdr(Connection) -i upgrade
#acl is_websocket hdr(Upgrade) -i websocket
use_backend ws_back if is_websocket
backend deny_back
#errorfile 403 /var/www/403.http
#http-request deny deny_status 403
http-request silent-drop if TRUE
server letsencrypt 127.0.0.1:54321
backend ws_back
#todo: add sticky session
#option http-server-close
#timeout tunnel 1h
server mdm-dev-backend-01 128.199.20.206:6000 check
backend https_back
server mdm-dev-apps-01 10.122.64.3:80 check
server mdm-dev-apps-02 10.122.64.4:80 check
