Ok, i have it working now and i’ll post it here in case someone else needs it.
Package lualdap is needed.
/etc/haproxy/haproxy.cfg
lua-load /etc/haproxy/ldap_group_check.lua
frontend frdp
# The parameter gets cut at the first ",". Hence replacing them with ";" for now.
# Why is this happening?
use_backend back_rdp_special if { lua.ldap_group_check('cn=special;dc=domain;dc=local') -m bool }
default_backend back_rdp
local lualdap = require("lualdap");
local function ldap_group_check(txn, group_dn)
group_dn = group_dn:gsub(";", ",", g)
local cookie = txn.f:rdp_cookie('mstshash')
-- Remove the domain part.
-- Ex. 'DOMAIN\user1' becomes 'user1'
cookie = cookie:gsub('%a+[\\]+','')
local retval = false
local ld = lualdap.open_simple("ldap://<ldapserver>:<port>",
"<binddn>",
"<passwor>")
if ld then
local search_filter = "(&(uid=" .. cookie ..")(memberOf=" .. group_dn .. "))"
for _, _ in ld:search { base = "dc=domain,dc=local",
scope = "subtree",
filter = search_filter } do
retval = true
break
end
else
core.log(core.err, "LDAP not connected!")
end
return retval
end
core.register_fetches('ldap_group_check', ldap_group_check)
This works as expected but one things makes me nuts.
I have to replace all “,” in the parameter (group DN) passed to my lua function as otherwise it gets cut at the first “,”.
