This is happening with, version 1.5.12 2015/05/02. I had no match with the ACL statement, but the error code indicated was 503, with the flags ‘SC’ which in no way indicates that we have a bad ACL statement. Wanted to know if this was addressed/fixed in the later versions ? Or is it worthwhile to put some error codes for these kind of errors ? A lot of time was killed due to this, which could have been prevented had the error code been more informative, or useful.
ACLs can be used in a lot of different ways, like denying request, selecting backends, etc.
I assume the bad ACL statement lead haproxy to switch the traffic to another, maybe the default backend, which had indeed problems explained by the SC flag?
Please share your configuration, as complete as possible and the log of this 503 error (should show the backend and server as well).
So, the acl statement looked like this,
"acl global hdr(host) -i 10.47.4.2, 10.47.4.2:80
use_backend default_backend if global
And the error in the log, looked something like this,
"72.20.160.156:52720 [27/Apr/2016:19:05:41.475] frontend frontend/ -1/-1/-1/-1/+0 503 +212 - - SC-- 88/0/0/0/0 0/0 {10.47.4.2||||Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.86 Safari/537.36} {|||} “GET / HTTP/1.1"”
Now the acl statement is not matching anything, and I do not have a default_backend section, so it is not doing anything. But the error log code “SC” is not at all informative, with this regard (like telling that bad acl statement or no backend matched or something).
Gonna need more configuration than that, especially front and backend configs.
frontend my_frontend
maxconn 1000
option forwardfor header x-e-client
capture request header Host len 128
capture request header X-Forwarded-For len 128
capture request header Content-Length len 16
capture request header Referer len 4096
capture request header User-Agent len 128
capture response header Server len 128
capture response header Location len 128
capture response header Content-Length len 16
use_backend my_backend if global
backend my_backend
#option prefer-last-server
option forwardfor header FK-Client-IP
cookie FKSID prefix indirect nocache
http-request set-header x-e-id 3.3.3.3
http-response set-header x-e-id 3.3.3.3
server 1.1.1.1 1.1.1.1:80 weight 255 maxconn 1000
server 2.2.2.2 2.2.2.2:80 weight 255 maxconn 1000
Do you need anything else other than these, which might have an effect on the error code which haproxy publishes in the logs ?
Ok, I see what you mean, you would see something like this:
haproxy[6379]: 127.0.0.1:53010 [29/Apr/2016:12:05:40.552] my_frontend my_frontend/<NOSRV> -1/-1/-1/-1/1 503 212 - - SC-- 0/0/0/0/0 0/0 "GET / HTTP/1.1"
With a config as simple as:
bind :80
acl global hdr(host) -i blablabla
backend my_backend
server google www.google.com:80
As you can see from the “NOSRV”, no backend was selected, and the timers indicate that as well.
I agree that SC is confusing, giving that the documentation insists this is a connection failure towards the server, which is clearly wrong in this case.
The behavior is consistent from at least 1.4.0 to current development branch. So there is no fix for this yet. Will have to report this on the mailing list.
Which mailing list do we need to report this at ?
haproxy@formilux.org (no need to subscribe)
Thanks!
