Haproxy smtpchk is flooding errors in smtpservers.log. The option “option smtpchk” in the (haproxy.cfg) SMTP backend is causing the below error at every check.
ERROR smtpserver: Socket to hostname (x.x.x.x) closed remotely.
java.net.SocketException: Connection reset
at java.base/java.net.SocketInputStream.read(Unknown Source)
at java.base/java.io.BufferedInputStream.fill(Unknown Source)
at java.base/java.io.BufferedInputStream.read(Unknown Source)
at org.apache.james.util.CRLFTerminatedReader.read(CRLFTerminatedReader.java:153)
at org.apache.james.util.CRLFTerminatedReader.readLine(CRLFTerminatedReader.java:113)
at org.apache.james.smtpserver.SMTPHandler.readCommandLine(SMTPHandler.java:751)
at org.apache.james.smtpserver.SMTPHandler.handleConnection(SMTPHandler.java:372)
at org.apache.james.util.connection.ServerConnection$ClientConnectionRunner.run(ServerConnection.java:432)
at org.apache.excalibur.thread.impl.ExecutableRunnable.execute(ExecutableRunnable.java:55)
at org.apache.excalibur.thread.impl.WorkerThread.run(WorkerThread.java:116)
After removing the smtpchk then the error disappears. Any ideas? I have even tried setting the correct domain for SMTP in the option smtpchk on haproxy.config file but its not working.
@lukastribus Any help would be appreciated?
I’m not entirely sure but one of my customers was having the same problem so I suggested they can check the ports and they found it was due to the port.
A fix has been committed and the next release will contain it:
opened 07:43PM - 03 Aug 22 UTC
closed 05:11PM - 25 Oct 22 UTC
type: bug
status: fixed
### Detailed Description of the Problem
When using smtpchk for SMTP service che… cks, HAProxy does not send a QUIT at the end of the transaction and simply drops the TCP connection. This results in Microsoft Exchange (in our case) recording thousands of Remote(SocketError) log messages per day as it sees each HAProxy service check as a failed connection.
### Expected Behavior
HAProxy should cleanly terminate the transaction with a QUIT after the test.
### Steps to Reproduce the Behavior
Configure an SMTP backend with smtpchk service checking and point to a Microsoft Exchange server
Monitor Exchange SMTP Receive Log for Remote(SocketError) messages
### Do you have any idea what may have caused this?
No code exists to send a QUIT command to SMTP target
### Do you have an idea how to solve the issue?
Believe src/tcpcheck.c needs updating with appropriate code to send a QUIT before closing the TCP connection
### What is your configuration?
```haproxy
maxconn 1048576
stats socket /var/run/haproxy.stat mode 600 level admin
log 127.0.0.1:514 local2
chroot /var/empty
pidfile /var/run/haproxy.pid
resolvers dns
parse-resolv-conf
timeout retry 10s
timeout resolve 10s
hold valid 10s
hold nx 10s
hold other 10s
hold obsolete 10s
accepted_payload_size 8192
maxconn 256000
timeout connect 5000ms
timeout client 5m
timeout server 5m
default-server on-marked-down shutdown-sessions init-addr last,none resolve-opts allow-dup-ip
backend exch-smtp-25-be
description Service ID XX exch-smtp backend
option smtpchk HELO xxxxxx.xxxxxxx.xxxxxxx.xxxxxx
server xxxxxx.xxxxxxx.xxxxxxx.xxxxxx_25 xxxxxx.xxxxxxx.xxxxxxx.xxxxxx:25 check resolvers dns fall 6
### Output of `haproxy -vv`
```plain
HAProxy version 2.4.2-553dee3 2021/07/07 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.4.2.html
Running on: Linux 3.10.0-1160.71.1.el7.x86_64 #1 SMP Tue Jun 28 15:37:28 UTC 2022 x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_PCRE=1 USE_PCRE_JIT=1 USE_THREAD=1 USE_LINUX_TPROXY=1 USE_OPENSSL=1 USE_ZLIB=1 USE_TFO=1 USE_NS=1 USE_SYSTEMD=1
DEBUG =
Feature list : +EPOLL -KQUEUE +NETFILTER +PCRE +PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 -CLOSEFROM +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS -OT -QUIC -PROMEX -MEMORY_PROFILING
Built with gcc compiler version 4.8.5 20150623 (Red Hat 4.8.5-44)
h2 : mode=HTTP side=FE|BE mux=H2 flags=HTX|CLEAN_ABRT|HOL_RISK|NO_UPG
Available services : none
[FCGI] fcgi-app
### Last Outputs and Backtraces
_No response_
### Additional Information
_No response_
