Hello everyone
I’m using HAProxy in TCP mode and would like to have some command line to query HAProxy process to get a list of current connected clients.
My clients have sessions for hours and i’d like to monitor that. I’ve been reading forums and documentation but i can’t find anything like this.
Any hint?
Regards
The management guide explain this, it’s show sess on the admin socket:
http://docs.haproxy.org/2.6/management.html#9.3-show%20sess
Thanks lukastribus, but the output i get with show sess is this:
0x7fba28027f40: proto=unix_stream src=unix:1 fe=GLOBAL be= srv= ts=00 epoch=0x7 age=0s calls=1 rate=1 cpu=0 lat=0 rq[f=c08002h,i=0,an=00h,rx=2m,wx=,ax=] rp[f=80008000h,i=0,an=00h,rx=,wx=,ax=] s0=[8,200008h,fd=13,ex=] s1=[8,204018h,fd=-1,ex=] exp=2m
I’m ignorant on what to do next, since I’m looking for something like this:
Remote IP Backend server Session time Session bytes
x.x.x.x 1.1.1.2 50m 4343243 kb
Regards!
As the output indicates, this is not an IP socket, but a unix socket. Unix sockets don’t have remote IP addresses.
As the documentation says:
The output format is intentionally not documented so that it can
freely evolve depending on demands. You may find a description of all fields
returned in src/dumpstats.c
