Hey Lukas and haproxy experts,
We’ve been using haproxy 1.8 successfully using:
nbproc 6
listen ssl-offload
bind 192.168.5.1:443 ssl crt ... alpn http/1.1,http/1.0 process 1
bind 192.168.5.1:443 ssl crt ... alpn http/1.1,http/1.0 process 2
bind 192.168.5.1:443 ssl crt ... alpn http/1.1,http/1.0 process 3
bind 192.168.5.1:443 ssl crt ... alpn http/1.1,http/1.0 process 4
bind 192.168.5.1:443 ssl crt ... alpn http/1.1,http/1.0 process 5
bind 192.168.5.1:443 ssl crt ... alpn http/1.1,http/1.0 process 6
server clear1 abns@clear1 send-proxy-v2-ssl-cn
This is to follow the advice of best practices to let haproxy use SO_REUSEPORT and distribute the load evenly between all processes.
Now when switching to 1.9 and setting nbproc = 1 and nbthread = 6, the question is: Is the best practice to set a single bind line and will haproxy correctly distribute the load between the threads instead?
Not sure, that’s why I’m asking
Or is the purpose of a dumb offloader a job for nbproc > 0 and forget about the threads?
Our conf is quite more complex, and the idea of using threads is mainly to have the best accuracy for stick-tables and our shaping logic, but if the best practice is to stick with nbproc > 0 for the offloader, we could use 2 different confs, though that’d a little ugly a little more annoying to manage.
Thanks,
Cris
