Haproxy 2.04 with openssl 1.1.1 TLS 1.3 not working
root@aasfproxy1wlg:/etc/haproxy# /usr/sbin/haproxy -vv
HA-Proxy version 2.0.4-1ppa2~xenial 2019/08/09 - https://haproxy.org/
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -O2 -fPIE -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
Built with multi-threading support (MAX_THREADS=64, default=8).
Built with OpenSSL version : OpenSSL 1.0.2g 1 Mar 2016
Running on OpenSSL version : OpenSSL 1.0.2g 1 Mar 2016
Built with PCRE2 version : 10.21 2016-01-12
h2 : mode=HTTP side=FE mux=H2
: mode=HTX side=FE|BE mux=H1
: mode=TCP|HTTP side=FE|BE mux=PASS
Available services :
prometheus-exporter
root@aasfproxy1wlg:/etc/haproxy# ldd /usr/sbin/haproxy
linux-vdso.so.1 => (0x00007ffd85ff2000)
libcrypt.so.1 => /lib/x86_64-linux-gnu/libcrypt.so.1 (0x00007f9069183000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f9068f69000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f9068d4c000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f9068b44000)
libssl.so.1.0.0 => /lib/x86_64-linux-gnu/libssl.so.1.0.0 (0x00007f90688db000)
libcrypto.so.1.0.0 => /lib/x86_64-linux-gnu/libcrypto.so.1.0.0 (0x00007f9068496000)
liblua5.3.so.0 => /usr/lib/x86_64-linux-gnu/liblua5.3.so.0 (0x00007f906825f000)
libsystemd.so.0 => /lib/x86_64-linux-gnu/libsystemd.so.0 (0x00007f9069a8b000)
libpcre2-8.so.0 => /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0 (0x00007f9067fe6000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f9067dd0000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f9067a06000)
/lib64/ld-linux-x86-64.so.2 (0x00007f90698f5000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f9067802000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f90674f9000)
libselinux.so.1 => /lib/x86_64-linux-gnu/libselinux.so.1 (0x00007f90672d7000)
liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f90670b5000)
libgcrypt.so.20 => /lib/x86_64-linux-gnu/libgcrypt.so.20 (0x00007f9066dd4000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f9066b64000)
libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0 (0x00007f9066950000)
I think even I can see the problem now but I dont know how to fix it. Would it be easier to do a complete rebuild of the server with a variant that has open ssl 1.1.1c out of the box. I think the latest debian has it?
Well your issue here is that you did everything instead of one thing.
You installed haproxy via apt-get install, then you build it from source, but without removing the old one first, then you didn’t update the system unit file and continued to use the old haproxy release running on OpenSSL 1.0.2.
I think a new Debian Buster setup would indeed be the most simple and reliable way to get TLS 1.3 to work.
Rebuilding today. Thank-you very much for all your help finding this. Will see how I get on with Buster.
Hi Lukas, Just one last message to say I installed buster, apt-install haproxy and I now have tls1.3 out of the box.
So thank you for all your patience while helping me on this.
