Built with multi-threading support (MAX_THREADS=64, default=6).
h2 : mode=HTTP side=FE mux=H2
: mode=HTX side=FE|BE mux=H1
: mode=TCP|HTTP side=FE|BE mux=PASS
while upgrading the openssl, do i need to uninstall the olderversion and install the latest one? or can i overwrite on top of it. Whats the suggestion step for upgrading openssl?
You should have read INSTALL instead, which I told you earlier, it addresses your exact problems, explaining howto build openssl and haproxy, without installing and impacting your system.
Here is the exact link to line 240 of the INSTALL document, please read it carefully and follow it, instead of blog posts on the Internet:
I told you to use CentOS 7 so you would not have to recompile openssl and haproxy yourself for your IE8 issue. You could have just recompiled openssl on your original OS instead, if you where gonna do that anyway.
The procedure works just fine in CentOS 7, I did include pthread and dl libs to make the haproxy build go through (adding ADDLIB="-ldl -lpthread" to the make line):
[lukas@localhost ~] $ wget https://www.openssl.org/source/openssl-1.1.1c.tar.gz
[lukas@localhost ~] $ tar -xzf openssl-1.1.1c.tar.gz
[lukas@localhost ~] $ cd openssl-1.1.1c
[lukas@localhost openssl-1.1.1c] $
[lukas@localhost openssl-1.1.1c] $ export STATICLIBSSL=/tmp/staticlibssl
[lukas@localhost openssl-1.1.1c] $ ./config --prefix=$STATICLIBSSL no-shared
[lukas@localhost openssl-1.1.1c] $ make && make install_sw
[lukas@localhost openssl-1.1.1c] cd ~
[lukas@localhost ~] $ wget http://www.haproxy.org/download/2.0/src/haproxy-2.0.4.tar.gz
[lukas@localhost ~] $ tar -xzf haproxy-2.0.4.tar.gz
[lukas@localhost ~] $ cd haproxy-2.0.4
[lukas@localhost haproxy-2.0.4] $ make TARGET=generic USE_OPENSSL=1 SSL_INC=$STATICLIBSSL/include SSL_LIB=$STATICLIBSSL/lib ADDLIB="-ldl -lpthread"
[lukas@localhost haproxy-2.0.4] $ ./haproxy -vv | grep OpenSSL
Built with OpenSSL version : OpenSSL 1.1.1c 28 May 2019
Running on OpenSSL version : OpenSSL 1.1.1c 28 May 2019
If you need your weak IE8 ciphers, don’t forget to configure your openssl build with enable-weak-ssl-ciphers.
Sorry to revive this old topic, but I would like to simplify the process for getting TLS1.3 on CentOS 7 in a manner, that is more sustainable in operations.
The EPEL repository allows to install openssl 1.1.1 in parallel to the existing version.
yum install epel-release
yum install openssl11
I would like to compile haproxy to dynamically (not statically) link to the shared library. Of course, when openssl11 is updated to a more recent version, I expect haproxy to not break.
Has anybody tried that already, and is it even possible to dynamically link to an alternative version of openssl, when compiling haproxy?
It installs to the following path: /usr/bin/openssl11
I may not be very good at compiling things, but I found a way to compile a working haproxy, linking dynamically to openssl11.
However, I am not sure if my solution will be stable on the next yum update of openssl11, because I had to manually create symlinks in /usr/lib64/. Otherwise, ld would fail to find the openssl11 shared library.
This is how I made it work:
yum install openssl11 openssl11-devel
yum remove openssl-devel
cd /usr/lib64/
ln -s libcrypto.so.1.1 libcrypto.so
ln -s libssl.so.1.1 libssl.so
cd /tmp/my_haproxy_build_directory/
make TARGET=generic USE_OPENSSL=1 SSL_LIB=/bin/openssl11 SSL_INC=/usr/include/openssl11
The resulting haproxy binary will display as:
# haproxy -vv | egrep 'HA-Proxy version|Running on:|OpenSSL'
HA-Proxy version 2.2.8-7bf78d7 2021/01/13 - https://haproxy.org/
Running on: Linux 3.10.0-1160.11.1.el7.x86_64 #1 SMP Fri Dec 18 16:34:56 UTC 2020 x86_64
Built with OpenSSL version : OpenSSL 1.1.1g FIPS 21 Apr 2020
Running on OpenSSL version : OpenSSL 1.1.1g FIPS 21 Apr 2020
Notice, without the symlinks, compilation will error out as follows:
ld -lssl --verbose
attempt to open //usr/x86_64-redhat-linux/lib64/libssl.so failed
attempt to open //usr/x86_64-redhat-linux/lib64/libssl.a failed
attempt to open //usr/lib64/libssl.so failed
attempt to open //usr/lib64/libssl.a failed
attempt to open //usr/local/lib64/libssl.so failed
attempt to open //usr/local/lib64/libssl.a failed
attempt to open //lib64/libssl.so failed
attempt to open //lib64/libssl.a failed
attempt to open //usr/x86_64-redhat-linux/lib/libssl.so failed
attempt to open //usr/x86_64-redhat-linux/lib/libssl.a failed
attempt to open //usr/local/lib/libssl.so failed
attempt to open //usr/local/lib/libssl.a failed
attempt to open //lib/libssl.so failed
attempt to open //lib/libssl.a failed
attempt to open //usr/lib/libssl.so failed
attempt to open //usr/lib/libssl.a failed
ld: cannot find -lssl
Is there way to tell the linker to look for other names (i.e. libssl.so.1.1 and libcrypto.so.1.1) in order to obsolete the nasty manual symlinks?
And does anyone know if this way to compile haproxy will be resilient to future yum updates?
