Haproxy 2.4 with k3s v1.32.3 +k3s1 and rancher two diff clusters
hi i just created my k3s cluster (all with local ips plus hostnames) one for rancher with 3 vms, another for master-x same 3 vms for master and 3 for workers for HA, im my case im using haproxy in front of everything heres my config: # Frontend único para todo el tráfico TLS entrante (Rancher y K3s)frontend h - Pastebin.com , and in my working cluster i just installer ingress-nginx the default from helm so i disabled traefik, i got my own .crt and .key for my certificate wildcard *.mydomain.com my issue is:
when i go to rancher.mydomain.com it works but nginx-test.mydomain.com (its a test deploment inside my working cluster) it shows 404, and viceversa after 2 minutes then rancher goes 404 and nginx-test.mydomain.com goes online, not sure what im doing wrong if its haproxy misconfig or something inside k3s. My main idea is to have a good HA so if some node goes off it wont get offline at all thats why i installed k3s poiting to haproxy ip.
thank you
