I messed around with my haproxy.cfg since I would like to differ between two servers, a cms.mydomain.org and a www.mydomain.org. Backend is a Tomcat9 server. While in a former configuration my fullchain.pem worked, haproxy suddenly doesn’t care about that certificate and the browser (FF) says I were using a self signe cert. (Mozilla Error: MOZILLA_PKIX_ERROR_SELF_SIGNED_CERT)
My haproxy.cfg:
pidfile /var/run/haproxy
maxconn 4000
ca-base /etc/ssl/apache2/certs
crt-base /etc/ssl/apache2/private
ssl-dh-param-file /etc/haproxy/dhparams.pem
ssl-skip-self-issued-ca
compression algo gzip
compression type text/html text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy application/atom+xml application/javascript application/x-javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest
option dontlog-normal
option httpclose
frontend http-in
bind *:443 ssl crt /etc/haproxy/fullchain.pem
bind quic4@0.0.0.0:443 name quic443 ssl crt /etc/haproxy/fullchain.pem proto quic alpn h3,h3-29,h3-28,h3-27 npn h3,h3-29,h3-28,h3-27 allow-0rtt curves secp521r1:secp384r1
http-response add-header alt-svc 'h3=":443"; ma=7200,h3-29=":443"; ma=7200,h3-Q050=":443"; ma=7200,h3-Q046=":443"; ma=7200,h3-Q043=":443"; ma=7200,quic=":443"; ma=7200'
# Redirect if HTTPS is *not* used
default_backend website
log /dev/log local2 debug
acl is_static path_beg /export/ /opencms/ /resources/ /javadoc/ /VAADIN/ /workplace /opencms-login/
acl is_website hdr_beg(host) -i www.mydomain.org
acl is_cmssite hdr_beg(host) -i cms.mydomain.org
use_backend website-static if is_website is_static
use_backend website if is_website
use_backend cmssite if is_cmssite
server www.mydomain.org 127.0.0.1:8080
backend website
http-request replace-header Destination ^([^\ :]*)\ /(.*) \1\ /opencms/\2
backend cmssite
server cms.mydomain.org 127.0.0.1:8082
