I would like to replace my current apache reverse proxy with haproxy.
I have defined 2 frontend section: http-input for incoming http requests and https-input for incoming https requests.
In this moment I have only java application as backend server, but in future I wuold like use haproxy to proxy request to IIS .
I have problem to redirect http request to https for some URL.
This is my haproxy confiration:
log 127.0.0.1 local2 debug
pidfile /var/run/haproxy.pid
maxconn 4000
timeout http-request 60s
timeout queue 1m
timeout connect 60s
timeout client 60s
timeout server 1m
timeout http-keep-alive 60s
timeout check 60s
maxconn 3000
frontend http-input
redirect scheme https if { hdr(host) -i mywebsite.mydomain.com } !{ ssl_fc }
frontend https-input
bind *:443 ssl crt /etc/haproxy/cert/mycert.pem
redirect prefix https://mywebsite.mydomain.com if { hdr(host) -i mywebsite.mydomain.com }
acl is_cu_hdr_nodoaric hdr(host) -i collaudo-wsnodo.aric.it
acl is_hdr_mywebsite hdr(host) -i mywebsite.mydomain.com
use_backend appserver1 if is_hdr_mywebsite
backend appserver1
option httpclose
server appserver1 appserver1.private.intra:8080 cookie appserver1 check inter 5000
In my log file I read this error:
localhost haproxy[17683]: 31.198.67.34:50543 [15/Dec/2017:15:11:37.320] https-input~ https-input/ 70/-1/-1/-1/70 302 151 - - LR-- 0/0/0/0/0 0/0 “GET /context2RA/ HTTP/1.1”
I have googled for 2 days and do not understand where is the problem! Please help me!
Thank you
