Caching web content with HAProxy is pretty difficult
I essentially need HAProxy to cache small web responses for a period of time. I am thinking NGINX is the issue here, but I’m not sure.
I am serving static files from NGINX with HAProxy sitting in front. I am not wanting to cache stuff with nginx. This is more of a general, learn-how-to cache stuff with HAProxy effectively, and I would want to be able to apply this anywhere. I would use Nuster, but it’s too old and I sort of need to use the newer HAProxy versions.
Expected behavior:
User requests example com/file.html
file.html cached in HAProxy memory for x seconds if not already cached
If file was already cached in HAProxy memory, it should send status 200OK with item if it was not in users browser cache, or status 304 if the browser did not request the entire item, but rather just a modification validation
HAProxy to only serve that file from memory cache until it expires, and make it impossible no matter what headers to bypass the HAProxy memory cache
The issue:
I cannot find a way for HAProxy to do this entirely. The web browsers send:
pragma, cache-control, if-modified-since, if-none-match etc. headers
When I remove all of those headers with http-request, everything caches properly in memory and it even sends the in-memory cache like it’s supposed to, except it does not send 304 to the browser if a simple refresh is done, it sends the entire object. I think I’m a little confused as to what http-request vs http-response cache headers do on the backend, user end and HAProxy and how HAProxy is interpreting these headers and deciding when/how to cache stuff.
Do I need to del a header or do some action like send 304 if cache-control header is cache-control: max-age=0?
Should or do I, or is it even possible to use a stick table to store an items cache status and just send 304 if the browser hasn’t request the full item? I’m going for the most minimalistic way to do this. I just need a very lightweight software like haproxy that proxies and caches a couple of things from nginx or a webserver, and I am not open to using Varnish, nginx or something else to cache content further back.
I’m just a little bit lost, so I would appreciate any guidance whatsoever.
I am using HAProxy 2.8 dev4
