0
I am attempting to implement a script to execute actions based on the state of my backend nodes. Below is the initial section of my lua script and also haproxy backend config
Despite these settings, I consistently receive the error message: “No backend associated with the transaction.”
I’ve tried changing the Lua invocation to the frontend and rearranging several lines, but the issue persists. As I’m relatively new to Lua, I would appreciate any guidance on what I might be missing.
-- haproxy.lua
-- Track the previous states of nodeA and nodeB
local previous_state_nodeA = "up" -- initial state assumed to be up
local previous_state_nodeB = "backup" -- initial state assumed to be backup
core.register_action("server_state_change", { "http-req", "tcp-req" }, function(txn)
-- Verify if the transaction is linked to a backend
if txn.b ~= nil then
local be = txn.b
local server = be:get_server(txn.sf:srv_name())
local state = server:get_stats()["status"]
if be.name == "mybackend" then
if server.name == "nodeA" then
-- Execute action if state change detected for nodeA
check_and_trigger_action_nodeA(state)
elseif server.name == "nodeB" then
-- Execute action if state change detected for nodeB
check_and_trigger_action_nodeB(state)
end
end
else
-- Log an error when no backend is associated with the transaction
core.log(core.err, "No backend associated with the transaction")
end
end)
Here are the details of my backend configuration:
backend mybackend
http-request lua.server_state_change
cookie Cookie prefix nocache
default-server inter 3s fall 3 rise 2
server nodeA nodea.example.net:80 check
server nodeB nodeb.example.net:80 check backup
