Haproxy for galera cluster read write split ACL
Hi, I have configured read write split for galera cluster using acl like this
# Define ACLs
acl is_write query -m str -i “INSERT”
acl is_write query -m str -i “UPDATE”
acl is_write query -m str -i “DELETE”
acl is_read query -m str -i “SELECT”
use_backend galera_read if is_read
use_backend galera_write if is_write
default_backend galera_write
it is not working, basically using the default backend always, so when i removed default backend i get server not reachable.
Any idea ho to fix this much appreciated.
Kind regards,
Hi
query sample fetch is HTTP oriented, this won’t work for SQL (mode tcp backend)
As HAProxy is not SQL-awayre, you probably need to inspect the raw tcp payload to get this to work
Okay, thanks a lot for the info
much appreciated
