I would like to run the 2 Horizon connection servers behind the LB, but as far as I know, only source balance algorithm will do the job, since I have to authenticate and there is no cluster mode, right?
I’ve tried this:
backend 3dcloudtest_ssl_back
balance source
option httpchk HEAD / HTTP/1.1\r\nHost:\ 3dcloudtes
retries 2
timeout server 31s
server hor-conn01 10.11.5.139:443 check inter 5s fall 4 rise 3 ssl verify none
server hor-conn02 10.11.5.138:443 check inter 5s fall 4 rise 3 ssl verify none
but if my connection is sent to server hor-conn01 and then it fails, I am redirected to hor-conn02 and I need to reauthenticate, but the problem is also that when hor-conn01 comes back online, I am redirected back to hor-conn01 having to reauthenticate once more. How could I avoid this las redirection?
Thanks.
