hello everybody
I have set up a HAproxy to handel about 100K rps and then proxied that to the 4 nginx
but suddenly all the connection from HAproxy to the nginxes become
connection wating (red line) and the connection established (blue line) become minimum and all the cpu’s that allocated to the haproxy become 100%
this is the HAproxy configuration :
nbproc 1
nbthread 8
cpu-map auto:1/1-8 0-7
maxconn 500000
timeout connect 7s
timeout client 14s
timeout server 14s
frontend https_in
maxconn 500000
and here is the kernel configuration:
net.ipv4.ip_forward=1
net.ipv4.ip_nonlocal_bind = 1
fs.file-max = 10000000
fs.nr_open = 10000000
net.ipv4.ip_local_port_range = 1024 65535
net.ipv4.tcp_max_syn_backlog = 65536
net.core.somaxconn = 65535
net.core.netdev_max_backlog = 65536
net.ipv4.tcp_max_orphans = 262144
and also keepalive timeout in nginxes are 30s
HAproxy Vevrsion : HA-Proxy version 2.3.10-1ppa1~focal 2021/04/24
OS Version : Ubuntu 20.04.2 LTS
Kernel Version : 5.4.0-74-generic
what could be the problem ?
