HAProxy is creating new TCP connection for each http request in spite of http-keep-alive
I configured HAProxy for ACL based distribution. Say, there is a header ‘msisdn’ in http requests whose value is of int type and HAProxy would distribute requests between 2 backend servers based on value of msisdn.
I created a Jmeter Test plan for testing this scenario – Contains 5 http requests, out of which, 3 requests should go to server1 and 2 to server2 based on value of msisdn header and ran 2 loops of it with single thread. Set Connection: Keep-Alive in http requests. Distribution works perfectly fine but tcpdump between HAproxy and backend server shows that for every http request, there is new tcp connection. I made sure to set option http-keep-alive and http-reuse always in defaults, frontend and backend sections of haproxy.cfg .
  1. haproxy.cfg :
Example configuration for a possible web application. See the
full configuration options online.
http://haproxy.1wt.eu/download/1.4/doc/configuration.txt
Global settings
# need to:
# /etc/sysconfig/syslog
log 127.0.0.1 local2
chroot      /var/lib/haproxy
maxconn     4000
user        haproxy
group       haproxy
# turn on stats unix socket
timeout http-request 3600000
timeout queue 3600000
timeout connect 3600000
timeout client 3600000
timeout server 3600000
timeout http-keep-alive 3600000
timeout check 3600000
maxconn 3000
http-reuse always
bind 10.200.208.96:9001
stats uri /stats
stats hide-version
stats auth haproxy:redhat
http-reuse always
frontend LB
bind 10.200.208.96:9005
acl msisdn_range_1 hdr(msisdn) -m int 0:4
acl msisdn_range_2 hdr(msisdn) -m int 5:9
use_backend LB if msisdn_range_1
use_backend CR if msisdn_range_2
round robin balancing between the various backends
backend LB
option tcp-check
http-reuse always
server 10.200.208.97 10.200.208.97:8585 check # active node
backend CR
option tcp-check
http-reuse always
server 10.200.208.96 10.200.208.96:8585 check # active node
  1. tcpdump screen shots:
Problem looks similar to topic https://discourse.haproxy.org/t/problems-enabling-keep-alive-over-to-high-latency-backend/2852 but in our case, client doesn’t close connection, HAProxy is creating new connection to server.
Any help would be highly appreciated.
Thanks!
Are you sure your backend doesn’t set a Connection: close header after the POST?
Yes, backend server doesn’t set Connection: close. Here is screenshot of server’s response:
Version of HAProxy used is 1.7.11 .
Can share a capture with frontend and backend data?
Attaching tcpdump between client and proxy, proxy and backend server. 172.16.11.219 is client ip. Haproxy is running on 10.200.208.96 and backend server is running on 10.200.208.97.
  1. tcpdump b/w client and proxy: https://packettotal.com/app/analysis?id=58680e155b1e91f15775c5ad8e1f2a61
  2. tcpdump b/w proxy and server: https://packettotal.com/app/analysis?id=656e894e0a31001440acb6a2d48debce
Really your client closes the connection after each requests:
Thanks @lukastribus, seems some timeout in client (Jmeter). Now I sent 3 http requests for whom 404 response was expected. This time response was very fast and all 3 requests used same tcp connection. Thanks again!
