We have some redirects set up in HAProxy and when the redirection happens, we can see it in the logs as expected, but sometimes it reports the correct status_code, and other times it doesn’t. It’s almost like something it overwriting the %ST log variable so that when the redirect happens it logs that value instead of the value sent to the client. I should note that the operation of the redirects is working as intended–this is purely a problem with what we are seeing in the logs.
Given the following log settings:
nbthread 4
log 127.0.0.1:9515 local0
log-send-hostname
frontend http
log-format %ci:%cp\ %T\ %ft\ %b/%s\ %Tq/%Tw/%Tc/%Tr/%Tt\ %ST\ %B\ %CC\ %CS\ %tsc\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ %hr\ %H\ %{+Q}r
redirect scheme https code 301
frontend default
redirect prefix https://location1 code 301 if is_acl_1 !is_acl_2
So when we send in an HTTP request, we correctly get a 301 to the client with the correct location and the logs show this as well
x.x.x.x:42973 06/Dec/2019:17:45:59 +0000 http http/<NOSRV> 0/-1/-1/-1/0 301 95 - - LR-- 7108/16/0/0/0 0/0 <hostname> "GET / HTTP/1.1"
When we send in an HTTPS request, we correctly get the 301 status_code to the client with the correct location, but our log looks like this
x.x.x.x:26080 06/Dec/2019:17:45:59 +0000 default default/<NOSRV> 60/-1/-1/-1/60 503 343 - - LR-- 7107/7090/0/0/0 0/0 {<headers>} <hostname> "GET <path> HTTP/1.1"
Please note that I have inserted the x.x.x.x, <headers>, <hostname>, and <path> strings to mask potentially sensitive data.
We do have a lot of other configuration values in there that I have left out, but we can start with this and I can add more configuration if needed to debug this further.
Haproxy version output
HA-Proxy version 2.0.7 2019/09/27 - https://haproxy.org/
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-format-truncation -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_PCRE2=1 USE_PCRE2_JIT=1 USE_GETADDRINFO=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with multi-threading support (MAX_THREADS=64, default=8).
Built with OpenSSL version : OpenSSL 1.1.1c 28 May 2019
Running on OpenSSL version : OpenSSL 1.1.1c 28 May 2019
Built with PCRE2 version : 10.32 2018-09-10
h2 : mode=HTTP side=FE mux=H2
<default> : mode=HTX side=FE|BE mux=H1
<default> : mode=TCP|HTTP side=FE|BE mux=PASS
Available services :
prometheus-exporter
