This post was originally a reply to this, but I feel this needs a bit more attention that it has received until then:
I’m trying to do some aggregation between processes
If you run HAProxy in multiprocess mode, your HTTP requests are probably load-balanced between the different processes. The stats are not shared between processes. So the value will differ between processes. Try to read the value of
haproxy_process_relative_process_idto know where a request was processed.
So far, I always used this pattern to collect and measure:
cpu-map 1 0
cpu-map 2 1
cpu-map 3 2
cpu-map 4 3
cpu-map 5 4
cpu-map 6 5
cpu-map 7 6
cpu-map 8 7
stats socket /run/p1.sock mode 660 process 1
stats socket /run/p2.sock mode 660 process 2
stats socket /run/p3.sock mode 660 process 3
stats socket /run/p4.sock mode 660 process 4
stats socket /run/p5.sock mode 660 process 5
stats socket /run/p6.sock mode 660 process 6
stats socket /run/p7.sock mode 660 process 7
stats socket /run/p8.sock mode 660 process 8
It is quite clear that each proc has a stats socket.
In a simplified example regarding only proc 1:
frontend stats_prom_proc_1
bind *:8404 interface eth1
option http-use-htx
stats uri /stats level admin process 1
stats refresh 10s
I can bind my /stats uri to a proc but not my prometheus-exporter service.
I can’t see how I could handle an aggregation on those time series, and use-service is not documented. My current exporter scrapes all the sockets and exposes an aggregated value to prometheus’ scrape.
