Hello all,
I want to use different backends by using regex but it is not working as expected. My configuration like as shown below.
acl cons path_reg ^/(test)/([a-z-0-9]+/){0,1}$
use_backend consistent if cons
For example, this config should work like this:
https://domain.com/test --> should switch to consistent backend
https://domain.com/test/?a=1 --> should not switch to consistent backend but to default
how can i get it?
Provide more examples please, I can’t tell what you are trying to achieve.
I mean, if a url has query string then it should switch to default backend if does not it should switch to another backend that I defined as consistent. I want to achieve this situation by using path_reg.
You cannot achieve that with path, because the query string is not in path.
https://cbonte.github.io/haproxy-dconv/2.0/configuration.html#7.3.6-path
This extracts the request’s URL path, which starts at the first slash and
ends before the question mark (without the host part).
Use query instead, like acl cons -m found query.
