I want to use Haproxy to do the Rate limiting the front end URL.
I tried the suggestions mentioned here. But, I see that using these, once it blocks it blocks for ever. So, this is like DDOS not the Rate limiting.
My requirement is that the customer can access the URL /XYZ000/ at 1000 RPS and /ABC000/ at 2000 RPS for second if more that than the prescribed number of requests received then the extra should be rejected. How do we achieve the same ?
I tried the following, but once it blocks , it blocks for ever which is like DDOS. Please help !
I am using this configuration and once it is blocked, it gets blocked. It is not limiting the rate, it blocks the access to the URL for ever like DDOS. Strange !
How can I achieve the Rate limiting, i.e limit the rate to the configured value, i.e only allow that rate.
** # Set up stick table to track request rates**
** #stick-table type binary len 8 size 1m expire 10s store http_req_rate(10s)**
** stick-table type integer size 1m store http_req_rate(10s)**
** # Subtract the current request rate from the limit**
** # If less than zero, set rate_abuse to true**
** acl rate_abuse var(req.rate_limit),sub(req.request_rate) lt 0**
** #acl rate_abuse var(req.request_rate) gt var(req.rate_limit)**
** # Deny if rate abuse**
** http-request deny deny_status 429 if rate_abuse**
