Hello.
Sorry, I am newbie in a web technologies and haproxy. Please advice how to achieve desired result, described below.
Centos 6.3 and haproxy 1.5.4.
I have several paired https web services. And I want to use haproxy as load balancer and availability checker.
The main and only requirement - full request forward to one of the servers, without https/ssl termination on haproxy.
So I see it like haproxy checks server availability(wthat I believe it does by default) and sends redirection request to one of the servers .
For example I have siteA.com and siteB.com which are back-end urls to access server1 and server2 directly. With site.com assigned as front-end of haproxy url.
So we put https://site.com or http://site.com in web browser ang go directly to siteA.com or siteB.com.
Desirably at this point haproxy should give away the connection and let direct communication client - server1 or server2.
Client should see siteA.com or siteB.com and continue to work only with this site till the disconnect.
I configured pass-through mode(included config of /etc/haproxy/haproxy.cfg below)
But what I see when I access site.com is site.com which isnot good
#------------------- GLOBAL SETTINGS ---------------------------
log 127.0.0.1 local0 debug
maxconn 4096
maxconn 2000
#------------------- FRONTEND HTTP ---------------------------
frontend default
acl site_acl hdr(Host) -i site.com
redirect scheme https code 301 if { hdr(Host) -i site.com } !{ ssl_fc }
#------------------- FRONTEND TCP ---------------------------
frontend tcp_in
bind *:8444
bind *:8445
bind *:8443
bind *:443
acl site_acl req.ssl_sni -i site.com
use_backend special_site if site_acl
option ssl-hello-chk
server site-A siteA.com:8443 check
server site-B siteB.com:8443 check
