Haproxy routing to invalid backend under the load
During a load we are observing when the TCP connections are high haproxy is sending traffic to invalid backend but from the logs i don’t have proof to show. In our setup, we run nginx server on the same node to render static files/responses. Within haproxy config we have backend rule to route to the localhost nginx server & other backend rules to the proper app backend. Under the load instead of sending traffic to app backend, few requests are incorrectly routed to nginx & resulting in 404 responses. Did anyone else notice this issue?
We are running haproxy, version info here…
HA-Proxy version 1.9.4 2019/02/06 - https://haproxy.org/
  TARGET  = linux2628
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
  OPTIONS = USE_LINUX_SPLICE=1 USE_LINUX_TPROXY=1 USE_LIBCRYPT=1 USE_ZLIB=1 USE_DL=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1 USE_PCRE_JIT=1
Built with OpenSSL version : OpenSSL 1.0.2k-fips  26 Jan 2017
Running on OpenSSL version : OpenSSL 1.0.2k-fips  26 Jan 2017
Built with Lua version : Lua 5.3.2
              h2 : mode=HTX        side=FE|BE
              h2 : mode=HTTP       side=FE
       <default> : mode=HTX        side=FE|BE
       <default> : mode=TCP|HTTP   side=FE|BE
Here is config snippet
  log 127.0.0.1:5432 local0 info
  log 127.0.0.1:5433 local0 emerg notice
  log /dev/log local0 info
  log /dev/log local0 emerg notice
  maxconn 200000
  stats socket /var/run/haproxy/socket mode 600 level admin
  stats socket /var/run/haproxy/stats mode 640 group telegraf level operator
  stats timeout 2m
  server-state-file global
  server-state-base /var/state/haproxy/
  tune.bufsize 32768
   backlog 10000
   timeout http-request 10s
   timeout queue 1m
   timeout client 135s
   timeout server 135s
   timeout tunnel 3600s
   timeout http-keep-alive 10s
   timeout check 10s
   timeout tarpit 60s
   option http-ignore-probes
   maxconn 120000
frontend http-in
  acl url_mypath path_reg /path
  use_backend app-backend if url_mypath
  default_backend nginx-local
backend nginx-local
  server nginxlocal 127.0.0.1:81 check inter 1m
backend app-backend
 server myapp myapp-lb:80 check inter 1m
@lukastribus @willy can you pls suggest
Can you try with nbthread 1 ?
@lukastribus Thanks for your suggestion, I will test more with this config change & update .
