I setup a haproxy(1.6.3) on ubuntu 16.04 to load balancing two web servers. From my earlier tests, the web servers can handle over 20k request/s. The web servers were tested against wrk2, and I verified number of requests in log. However, with haproxy in front of web servers, it seems that the request per second is limited to about 6k request/s. Is there anything wrong in haproxy config?
haproxy.cnf
maxconn 102400
# https://serverfault.com/questions/504308/by-what-criteria-do-you-tune-timeouts-in-ha-proxy-config
timeout check 5000
timeout client 30000
timeout server 30000
timeout tunnel 3600s
listen web-test
option http-keep-alive # connections will no longer be closed after each request
server test1 SERVER1:80 check maxconn 20000
server test2 SERVER2:80 check maxconn 20000
If runnign wrk with 3 instances, I get approximately the same result:
./wrk -t4 -c100 -d30s -R4000 http://HAPROXY/
Running 30s test @ http://HAPROXY/
4 threads and 100 connections
Thread calibration: mean lat.: 1577.987ms, rate sampling interval: 7139ms
Thread calibration: mean lat.: 1583.182ms, rate sampling interval: 7180ms
Thread calibration: mean lat.: 1587.795ms, rate sampling interval: 7167ms
Thread calibration: mean lat.: 1583.128ms, rate sampling interval: 7147ms
Thread Stats Avg Stdev Max +/- Stdev
Latency 8.98s 2.67s 13.93s 58.43%
Req/Sec 516.75 11.28 529.00 87.50%
64916 requests in 30.00s, 51.69MB read
Requests/sec: 2163.75 # Requests/sec decrease slightly
Transfer/sec: 1.72MB
Stats from haproxy:
If running wrk with 1 instance to one of the web server without haproxy:
./wrk -t4 -c100 -d30s -R4000 http://SERVER1
Running 30s test @ http://SERVER1
Thread calibration: mean lat.: 1.282ms, rate sampling interval: 10ms
Thread calibration: mean lat.: 1.363ms, rate sampling interval: 10ms
Thread calibration: mean lat.: 1.380ms, rate sampling interval: 10ms
Thread calibration: mean lat.: 1.351ms, rate sampling interval: 10ms
Latency 1.41ms 0.97ms 22.42ms 96.48%
Req/Sec 1.05k 174.27 2.89k 86.01%
119809 requests in 30.00s, 98.15MB read
Requests/sec: 3993.36 # Requests/sec is about 4k
Transfer/sec: 3.27MB
haproxy -vv
HA-Proxy version 1.6.3 2015/12/25
Copyright 2000-2015 Willy Tarreau willy@haproxy.org
TARGET = linux2628
CC = gcc
CFLAGS = -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
OPTIONS = USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.0.2g-fips 1 Mar 2016
Running on OpenSSL version : OpenSSL 1.0.2g 1 Mar 2016
Built with PCRE version : 8.38 2015-11-23
Copyright 2000-2015 Willy Tarreau <willy@haproxy.org>
TARGET = linux2628
CC = gcc
I know that ab is not a very precise way to test this, but I thought haproxy should give a better result than a single node. However, the results show the opposite.
ab test HAPROXY
ab -n 10000 -c 10 http://HAPROXY/
Requests per second: 4276.18 [#/sec] (mean)
ab test SERVER1
ab -n 10000 -c 10 http://SERVER1/
Requests per second: 9392.66 [#/sec] (mean)
ab test SERVER2
ab -n 10000 -c 10 http://SERVER2/
Requests per second: 8513.28 [#/sec] (mean)
The VM is single core, so there is no need use nbproc. Plus, I monitor the cpu, memory usage, all VMs use less then 30% cpu, and 20% memory. There must be something wrong about the haproxy configs or my system configs.
