I am having a strange problem…
I am using Haproxy as RDP-loadbalancer to stick on the cookie:
stick-table type string len 4 size 20k expire 12h store conn_cur,conn_rate(5m) peers loadbalancer_replication
stick on rdp_cookie(mstshash)
Now the strange part: My monitoring is connecting without cookie. I would expect, that as there is no new entry in the sticky-table, there is a fallback to the configured round-robin. But: The connections without cookie are always assigned to the same backend-server.
When I check the sticky-table, there is no entry for the connection.
→ How can the connection be sticky, if there is no entry in the sticky-table?
Inspection delay is set and everything is working perfect as long, as the RDP cookie does provide the username, but otherwise, there is a stickyness without an entry in the sticky table.
IMHO, also multiple connections from ONE host should be balanced round robin, if there is no entry in the sticky table.
Then yes, new RDP connections from a different client IP should hit a different server.
But I think the same client IP will re-use the existing connection because option tcpka is being used to keep the connection alive.
I could be wrong though, I havent tested this in a while.
Have you got some more information about how you are testing it?
