Haproxy stops working Connect() failed for backend local address already in use
I am running HAproxy package in pfsense (HyperV) and I am facing a strange issue.
Every few days or twice a day haproxy fails to forward o backends. The backend start to go randomly up and down even though are on local lan and have enough resources . Ping is ok and also if i use curl from console to the back end works ok.
From logs i see this message:
pfSense01 haproxy[75001]: Connect() failed for backend IIS: local address already in use.
At first i thought it was port exchaustion problem so i added multiple ip to reach backend,but the issue remains.
Restarting HAprox does not fix the problem,only restarting full pfsense works.
Im using pfsense CE 2.7.2-RELEASE
haproxy: 2.8.3-86e043a
And this is my config
maxconn 120000
log /var/run/log local0 err
uid 80
gid 80
nbthread 8
hard-stop-after 30s
chroot /tmp/haproxy_chroot
#cpu-map auto:1/1-6 0-5
ssl-default-bind-ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:AES128-GCM-SHA256:AES128-SHA256:AES128-SHA:AES256-GCM-SHA384:AES256-SHA256:AES256-SHA:DHE-DSS-AES128-SHA:DES-CBC3-SHA
option contstats
timeout tunnel 1800s
listen HAProxyLocalStats
stats refresh 10
stats admin if TRUE
stats show-legends
timeout client 5000
timeout server 5000
frontend Porta_80-177
bind WAN:80 name WAN:80
option socket-stats
option dontlog-normal
acl https ssl_fc
timeout client 30000
default_backend Porta_80_ipvANY
frontend RABBITMQ-181
bind WAN:5672 name WAN:5672 transparent
#source 0.0.0.0 usesrc clientip
default_backend RABBIT_MQ_ipvANY
frontend Porta_SSL_ALL
bind 0.0.0.0:443 name 0.0.0.0:443 ssl crt-list /var/etc/haproxy/Porta_SSL_ALL.crt_list
option socket-stats
option log-separate-errors
acl https ssl_fc
acl mycerts var(txn.txnhost) -m end -i mydomain.com
acl mycerts var(txn.txnhost) -m end -i mydomain1.com
acl mycerts var(txn.txnhost) -m end -i mydomain2.com
acl aclcrt_Porta_SSL_ALL var(txn.txnhost) -m reg -i ^([^.]).mydomain1.com(:([0-9]){1,5})?$
acl aclcrt_Porta_SSL_ALL var(txn.txnhost) -m reg -i ^mydomain1.com(:([0-9]){1,5})?$
).mydomain2.com(:([0-9]){1,5})?$
acl aclcrt_Porta_SSL_ALL var(txn.txnhost) -m reg -i ^mydomain2.com(:([0-9]){1,5})?$
acl aclcrt_Porta_SSL_ALL var(txn.txnhost) -m reg -i ^([^.]*).mydomain.com(:([0-9]){1,5})?$
acl aclcrt_Porta_SSL_ALL var(txn.txnhost) -m reg -i ^mydomain.com(:([0-9]){1,5})?$
use_backend Porta_80_ipvANY if mycerts aclcrt_Porta_SSL_ALL
frontend RABBITMQ-local
bind 192.168.100.100:5672 name 192.168.100.100:5672 transparent
frontend IP-178
bind wanip2:80 name wanip2:80
acl https ssl_fc
id 100
option log-health-checks
http-check send meth OPTIONS ver HTTP/1.1\r\nHost:\ haproxy.mydomain.com:80\r\nAccept:\ /
timeout connect 30000
timeout server 30000
option httpchk
server IIS2_1 192.168.100.2:80 id 101 check inter 15000 source 192.168.100.14:1025-65000
server IIS2_2 192.168.100.2:80 id 102 check inter 15000 source 192.168.100.15:1025-65000
server IIS2_3 192.168.100.2:80 id 103 check inter 15000 source 192.168.100.16:1025-65000
id 104
server rabbit_01 192.168.100.1:5672 id 105 check inter 5000
server rabbit_02 192.168.100.2:5672 id 106 check inter 5000
server rabbit_03 192.168.100.3:5672 id 107 check inter 5000
Any help would be appreciated
I assume we are talking about backend Porta_80_ipvANY.
Leave only a single backend server and make sure you do not specify a source IP and more importantly that you do not specify a source port range. Specifying a soure port range is dangerous and slow in a multi threaded enviroment like this. Source port selection should be done by the kernel instead.
If it happens again, check netstat -nt or ss -s and ss -l output.
i already had only one back end without source ip and port. but state table reached 65k and we had problems. when i added multiple source the state table increased. but the issue persisted.
we have like 10k-20k active connections(like websockets) and like 200-300req/s
The strange thing is that it happens randomly. it can happen during peak times or at 4 Am when there like 1k connections
We have also a lot of Time_wait anf Fin2 connections but this also does not explain when it crashes at 4 am
I dissabled carp ip and use only ip of interfaces and see if it fixes anything
I have used haproxy for years (installed in ubuntu) and did not have these problems.
Considering that a haproxy restart does not fix the situation, but you have to reboot, likely you are exhausting fw/pf sessions.
Pf state table is far less than its limit. when it happens during the night state table is like 14k entries and my pfsense state limit is 2M.
Well something is exhaustion state on the OS, if it isn’t pf than it could just be the actual sockets.
