Currently, I am trying to configure a load balancer from where the traffic will be sent to a Kubernetes cluster. At the edge of the cluster, Istio ingress is serving the cluster’s external request. HAProxy version 1.8
I can access the service using the below command from outside the cluster.
curl -k -HHost:httpbin.example.com --resolve httpbin.example.com:32009:192.168.50.10 https://httpbin.example.com:32009/status/418:
Below is my HAProxy configuration:
Frontend:
frontend https
bind *:443 ssl crt /etc/ssl/certs/site.pem
default_backend httpbin
Backend:
backend httpbin
acl httpbin_app req_ssl_sni -i httpbin.example.com
use-server master if httpbin_app
server master 192.168.50.10:32009 check ssl verify none
http-request set-header Host httpbin.example.com
Using HAProxy I am getting 503 always. Also during startup, HAProxy is saying the below line:
haproxy[14260]: backend httpbin has no server available!
Can you please help to find out the right configuration for backend?
