Hi Lukas! I’ve resolved my problem! Thank you so much!
You may want to set persistent ID’s for each backend server, that way, it doesn’t depend on the sequence of your servers in the configuration file.
One more question. I use least conn balancing with sticky tables, could I save active connections count before reload haproxy?
I don’t know what you mean by “save active connections count”.
