Hello
I work in a company in which we use HAProxy for all our loadbalancing; frontend but also between application servers and replicated database servers. It’s with the latter that we’ve encountered some issues.
Our databaseservers work with master-master replication and in between these servers and the application servers there are two haproxy loadbalancers (active/passive) using sticky tables so that the same database server is used unless it is marked as down, then it should switch to the other database server. Most of the time this doens’t cause any issues but we’ve encountered that when we reload haproxy due to a new configuration the sticky tables are reset meaning that when for any reason what so ever the backup databaseserver was marked as the active one by haproxy after the reload this will switch back to the not backup one and this can and has caused issues for us.
The reason that this can cause issues is because we use connection pools on our application servers meaning that if haproxy does a switchover it can happen that the application server still has open connection to the previously active/now passive server. This in case breaks replication because the application servers can then write to both database servers.
Below you can find our HAProxy configuration, does anybody have any tips on how we can ensure that the sticky-tables are stored when doing a haproxy reload?
Thank you for your help!
Configuration
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
stats socket /var/lib/haproxy/stats mode 666 level user
stats socket /var/lib/haproxy/stats-admin mode 600 level admin
ssl-default-bind-ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:!DSS
ca-base /etc/pki/tls/certs
crt-base /etc/pki/tls/certs
retries 2
timeout connect 100ms
timeout server 3600s
timeout client 3600s
log-format %ci:%cp\ |\ {|}\ |\ %ft\ %b/%s\ 0/%Tw/%Tc/0/%Tt\ %ST\ %B\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ %hs\ ""
listen mysql-cluster
bind *:3306
option mysql-check user haproxy_check
stick-table type ip size 100
stick on dst
server db01a <ip>:3306 check inter 500 fall 5 on-marked-down shutdown-sessions
server db01b <ip>:3306 check inter 500 fall 5 backup on-marked-down shutdown-sessions
