Hi
I’m trying to run ADFS and WAP in HAProxy in a simple TCP setup…
ADFS running on 10.0.1.10/24 eth0
WAP running on 10.0.2.10/24 eth1
Default route is set for both nets:
MyHaproxy: #
Destination Gateway Genmask Flags Metric Ref Use Iface
default 10.0.1.1 0.0.0.0 UG 0 0 0 eth0
default 10.0.2.1 0.0.0.0 UG 1 0 0 eth1
Configuration
maxconn 6000
uid 99
gid 99
ssl-default-server-options force-tlsv12 no-tls-tickets
ssl-default-server-ciphers ECDH+AESGCM:ECDH+CHACHA20:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA+AESGCM:RSA+AES:!aNULL:!MD5:!DSS
ssl-default-bind-options force-tlsv12 no-tls-tickets
ssl-default-bind-ciphers ECDH+AESGCM:ECDH+CHACHA20:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA+AESGCM:RSA+AES:!aNULL:!MD5:!DSSdefaults
timeout connect 5000ms
timeout client 50000ms
timeout server 50000msfrontend ADFSFrontend
bind 10.0.1.10:443 interface eth0
default_backend ADFSBackendfrontend WAPFrontend
bind 10.0.2.10:443 interface eth1
default_backend WAPBackendbackend ADFSBackend
server 450adfs01 10.0.1.101:443 check
server 450adfs02 10.0.1.102:443 checkbackend WAPBackend
server 450wap01 10.0.2.101:443 check
server 450wap02 10.0.2.102:443 check
Everything works fine if I access ADFS from everywhere, except from the WAPBackend servers - it seems this fails as the incoming traffic is coming from eth0, but the outgoing is presumed to go out eth1…
If I make ifdown eth1, the traffic is fine.
Best regards
Flemming
