Hi.
I have a problem with proxying Windows 10/Server RDP, the point is when i type srv1.example.com RDP app connects to virtual machine srv1 (win 10 pro) with ip 10.10.0.1, when i type srv2.example.com it connects to (win srv 2022) ip 10.10.0.2. With that config redirections work without problem but no matter what subdomain i type (have to be rdirected on domain server to my public ip) i connects to server in config (no checking domain etc).
backend bk_rdp
persist rdp-cookie
timeout server 1h
timeout connect 4s
option tcp-check
server srv1 10.10.0.1:3389
But when i do smth like this (checking domain name and connecting to coresponding srv), RDP automatically refuses connection and post error 0x904 (cypher or network problems):
frontend ft_rdp
bind *:3389
timeout client 1h
tcp-request inspect-delay 2s
tcp-request content accept if RDP_COOKIE
use_backend bk_rdp_srv1 if host_srv1
use_backend bk_rdp_srv2 if host_srv2
backend bk_rdp_srv1
persist rdp-cookie
timeout server 1h
timeout connect 4s
option tcp-check
server server1 10.10.0.1:3389
backend bk_rdp_srv2
persist rdp-cookie
timeout server 1h
timeout connect 4s
option tcp-check
server server2 10.10.0.2:3389
Anyone have any idea?
I know there is option with windows server rd gateway but i dont want to use it, “serwers” have to be separated and have no communication between each other.
Have you tried using ssl_fc_sni instead? Quoting the documentation:
This fetch is different from “req.ssl_sni” above in that it applies to the connection being deciphered by HAProxy and not to SSL contents being blindly forwarded
@rafamiga i have tried nearly the same as @Patryk . Withoout cert in bind both versions ssl_fc_sni and req_ssl_sni will be ignored. If i add an global cert to bind then i get an SSL handshake error: “SSL handshake failure (error:0A00010B:SSL routines::wrong version number)”
The 10B error sometimes means that instead of doing TLS the port does plaintext. At least what I think so based on your description – you didn’t write which “side” the error is produced by – the port haproxy binds to or communication with backend server.
Try openssl s_client -connect <ip>:<port> first. iI you get 10B error on connection try connecting without TLS, with curl http://<ip>:<port> or redesktop if it’s a RDP port.
stats socket /var/lib/haproxy/stats level admin
frontend inbound_rdp
bind 192.168.0.100:3389 name rdp ssl crt /etc/haproxy/terminalserver.pem ssl-min-ver TLSv1.2 ssl-max-ver TLSv1.3
# tcp-request content accept if { req_ssl_hello_type 1 }
timeout client 1h
option tcpka
tcp-request content reject if { req_ssl_hello_type 1 }
acl pool_cad_sni req_ssl_sni -i terminalservercad.my.domain
use_backend terminalservercad_rdp if pool_cad_sni
default_backend terminalserver_rdp
#balance leastconn
persist rdp-cookie
balance rdp-cookie
timeout server 1h
timeout connect 4s
option tcp-check
tcp-check connect port 3389
default-server inter 3s rise 2 fall 3
server ts01 ts01.my.domain:3389 weight 10 check
server ts02 ts02.my.domain:3389 weight 10 check
#balance leastconn
persist rdp-cookie
balance rdp-cookie
timeout server 1h
timeout connect 4s
option tcp-check
server ts05 ts05.my.domain:3389 weight 10 check
server ts06 ts06.my.domain:3389 weight 10 check
If i remove “ssl crt /etc/haproxy/terminalserver.pem ssl-min-ver TLSv1.2 ssl-max-ver TLSv1.3” from the fronend bind → it works but my Windows clients get an certificate issue because the bind address (DNS name) ist part of the target rdp certificate. But with the above config it shows me the ssl handshake error. So i think that the frontend configuration makes the issue.
