i’m using HA-Proxy version 1.8.8-1ubuntu0.4 2019/01/24 … config file is working, i want to add the capability to select a server based on a url parameter e.g. https://foobar-nd.ddns.net/?netdata_server=openvpn -> 192.168.1.235:19999
the key sections are below with the full config file at the end as well as the traceback … i’m new to haproxy so i’m not sure what is wrong however the trace show the initial GET causing an issue … all other portions of the config file are working
acl is-netdata-server-set-properly urlp_reg(netdata_server) ^(openvpn|poolside|rosegarden|stage|ha|pihole|unifi|unms|firepit|greenhouse|fireplace|genmon)
http-request set-var(req.netdata_server) urlp(netdata_server) if is-netdata-server-set-properly
use_backend backend-%[var(req.netdata_server)] if is-netdata-server-set-properly { ssl_fc_sni -i foobar-nd.ddns.net }
backend backend-openvpn
server default-netdata 192.168.1.235:19999 check no-ssl
----------------- output
00000009:https.accept(0005)=000a from [192.168.1.1:54494] ALPN=
0000000a:https-front.accept(0006)=000c from [192.168.1.1:54494] ALPN=
0000000a:https-front.clireq[000c:ffffffff]: GET /dashboard.js?v20181211-1 HTTP/1.1
0000000a:https-front.clihdr[000c:ffffffff]: Host: foobar-nd.ddns.net
0000000a:https-front.clihdr[000c:ffffffff]: Connection: keep-alive
0000000a:https-front.clihdr[000c:ffffffff]: User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/74.0.3729.169 Safari/537.36
0000000a:https-front.clihdr[000c:ffffffff]: Accept: /
0000000a:https-front.clihdr[000c:ffffffff]: Referer: https://foobar-nd.ddns.net/?netdata_server=openvpn
0000000a:https-front.clihdr[000c:ffffffff]: Accept-Encoding: gzip, deflate, br
0000000a:https-front.clihdr[000c:ffffffff]: Accept-Language: en-US,en;q=0.9
0000000a:https-front.clihdr[000c:ffffffff]: Cookie: session=05213fd425d0545d2533307a0ae60fa6
0000000a:blueiris-backend.srvrep[000c:adfd]: HTTP/1.1 404 Not Found
0000000a:blueiris-backend.srvhdr[000c:adfd]: Server: BlueServer/4.8.6.3
0000000a:blueiris-backend.srvhdr[000c:adfd]: Date: Sat, 25 May 2019 14:51:20 GMT
0000000a:blueiris-backend.srvhdr[000c:adfd]: P3P: CP=“CAO COR CURa ADMa DEVa OUR IND ONL COM DEM PRE”
0000000a:blueiris-backend.srvhdr[000c:adfd]: Access-Control-Allow-Origin: *
0000000a:blueiris-backend.srvhdr[000c:adfd]: Set-Cookie: session=05213fd425d0545d2533307a0ae60fa6; path=/
0000000a:blueiris-backend.srvhdr[000c:adfd]: Connection: Close
---------------------- haproxy.cfg
maxconn 100
timeout connect 20s
timeout client 50s
timeout server 50s
timeout tunnel 1h
bind 192.168.1.235:9000
maxconn 10
stats hide-version
stats refresh 30s
stats show-node
# stats auth admin:password
stats uri /haproxy?stats
frontend https
bind *:443
use_backend openvpn-backend if { req_ssl_sni -i foobar.ddns.net }
default_backend https-back
frontend https-front
bind unix@/var/run/haproxy.sock ssl crt /etc/letsencrypt/live/foobar.ddns.net/haproxy.pem accept-proxy
use_backend home-assistant-backend if { ssl_fc_sni -i foobar-ha.ddns.net }
use_backend nextcloud-backend if { ssl_fc_sni -i foobar-nc.ddns.net }
use_backend blueiris-backend if { ssl_fc_sni -i foobar-bi.ddns.net }
use_backend pihole-backend if { ssl_fc_sni -i foobar-dns.ddns.net }
use_backend unifi-backend if { ssl_fc_sni -i foobar-unifi.ddns.net }
use_backend unms-backend if { ssl_fc_sni -i foobar-unms.ddns.net }
use_backend haproxy-backend if { ssl_fc_sni -i foobar-haproxy.ddns.net }
default_backend blueiris-backend
frontend http
bind :80
backend https-back
server https-front unix@/var/run/haproxy.sock send-proxy-v2
timeout server 2h
server openvpn 192.168.1.235:444
server haproxy 192.168.1.235:9000 no-ssl check
http-request redirect location /haproxy?stats if { path / }
server pi-hole 192.168.5.2:80 check no-ssl
rspadd X-Frame-Options:\ SAMEORIGIN
http-request redirect location /admin/ if { path / }
server unifi 192.168.1.16:8443 ssl verify none check
http-request redirect location /manage/site/kab9w4dv/dashboard if { path / }
server unms 192.168.1.207 ssl verify none
http-request redirect location /dashboard if { path / }
server home-assistant 192.168.1.123:8123 check
server nextcloud 192.168.1.123:80 check
server blueiris 192.168.1.36:1050 check
