Describing
Cluster of two VM was deployed for HA based on ton of coolguides of pro guys.
e.g. : High Available HA Proxy Tutorial With Keepalived
Pipeline
HAproxy + Keepalived
More specifically
Hosts:
haproxy1.mycompany.com (10.10.199.101 Master)
haproxy2.mycompany.com (10.10.199.102 Slave)
Floating IP address:
myservice.mycompany.com (10.10.199.150)
Expected behavior
Using VIP via Keepalived will not result in losses.
Testing HA via services
- R/W operations S3 object storage (minio)
- Queries in Postgresql
Configs
Keepalived MASTER
global_defs {
router_id haproxya1
enable_script_security
script_user root
vrrp_script haproxy_check {
script "/usr/libexec/keepalived/haproxy_check.sh"
interval 2
weight 100
vrrp_instance VI_1 {
interface enp6s18
state MASTER
priority 100
virtual_router_id 101
advert_int 1
unicast_src_ip 10.10.199.101
unicast_peer {
10.10.199.102
virtual_ipaddress {
10.10.199.150
track_script {
haproxy_check
Keepalived BACKUP
global_defs {
router_id haproxya2
script_user root
interval 2
weight 100
interface enp6s18
state BACKUP
priority 50
advert_int 1
unicast_src_ip 10.10.199.102
unicast_peer {
10.10.199.101
virtual_ipaddress {
10.10.199.150
track_script {
haproxy_check
Common HAproxy config
maxconn 100000
retries 10
timeout client 30m
timeout connect 30s
timeout server 30m
timeout check 5s
no option http-server-close
http-reuse always
listen hapserver
bind 10.10.199.150:7000
stats uri /
# PostgreSQL
listen postgres
bind 10.10.199.150:5000
server postgres 10.10.199.123:5430 check
# S3 MinIO
listen s3minioWEB
bind myservice.mycompany.com:9001 ssl crt /etc/haproxy/ssl/myservice.mycompany.com.pem
server minio1 minio1.mycompany.com:9001 check inter 2s
server minio2 minio2.mycompany.com:9001 check inter 2s
server minio3 minio3.mycompany.com:9001 check inter 2s
server minio4 minio4.mycompany.com:9001 check inter 2s
listen s3minioAPI
bind myservice.mycompany.com:9000 ssl crt /etc/haproxy/ssl/myservice.mycompany.com.pem
server minio1 minio1.mycompany.com:9000 check inter 2s
server minio2 minio2.mycompany.com:9000 check inter 2s
server minio3 minio3.mycompany.com:9000 check inter 2s
server minio4 minio4.mycompany.com:9000 check inter 2s
During testing, a long task of one of the services (Postgresql, S3) was run (from another computer in the same local corporate network). While the task was in process, MASTER (haproxy1) was stopped. As expected, VIP was raised on another host.
However, when testing S3 minio always connection was closed.
But when testing Postgresql the error appeared every other time.
Query testing was done using the script:
#!/bin/bash
export DB_HOST="10.10.199.14"
export DB_PORT="5000"
export DB_NAME="db"
export DB_USER="user"
export PGPASSWORD='password'
start_time=$(date +%s)
end_time=$(( start_time + 50 ))
iterator=1
echo "Start"
while [[ $(date +%s) -le $end_time ]]; do
echo "cur: $iterator"
psql -h "$DB_HOST" -p "$DB_PORT" -U "$DB_USER" -d "$DB_NAME" -c "INSERT INTO haptest (num, timest) VALUES ("$iterator", CURRENT_TIMESTAMP)"
iterator=$((iterator+1))
done
iterator=$((iterator-1))
echo "Made records: $iterator"
echo "End"
Guys, could you help, whether i mistaken somewhere or did testing the wrong way?
