Hello.
I am trying to get the number of status codes for each domain separated by protocol.
I can get the number of request data in the domain using http-request track-sc.
However, when tested with the config below, the http-response track-sc and http-response sc-inc-gpc do not seem to work correctly.
I would like to know what is wrong in the config and how to use http-response track-sc and http-response sc-inc-gpc correctly.
I would be grateful if you could give me a guide on what is wrong and what needs to be corrected.
config
frontend HTTP
bind *:80 http-request set-var(txn.host) req.hdr(host),lower,field(1,:) http-request track-sc0 var(txn.host) table BK_ALL http-request track-sc1 var(txn.host) table BK_HTTP http-response track-sc0 var(txn.host) table BK_HTTP_23 if { status ge 200 } { status lt 400 } http-response sc-inc-gpc0(0) if { status ge 200 } { status lt 300 } http-response sc-inc-gpc1(0) if { status ge 300 } { status lt 400 } http-response track-sc0 var(txn.host) table BK_HTTP_45 if { status ge 400 } { status lt 600 } http-response sc-inc-gpc0(0) if { status ge 400 } { status lt 500 } http-response sc-inc-gpc1(0) if { status ge 500 } { status lt 600 } default_backend BK_DEFAULTfrontend HTTPS
bind *:443 ssl crt-list /etc/haproxy/ssl/cert-list.txt tls-ticket-keys /etc/haproxy/ssl/tls-ticket.key alpn h2,http/1.1 npn h2,http/1.1 acl http2 ssl_fc_alpn -i h2 acl http2 ssl_fc_npn -i h2 http-request set-var(txn.host) req.hdr(host),lower,field(1,:) http-request track-sc0 var(txn.host) table BK_ALL http-request track-sc1 var(txn.host) table BK_HTTPS if !http2 http-request track-sc2 var(txn.host) table BK_HTTP2 if http2 http-response track-sc0 var(txn.host) table BK_HTTPS_23 if { status ge 200 } { status lt 400 } !http2 http-response sc-inc-gpc0(0) if { status ge 200 } { status lt 300 } !http2 http-response sc-inc-gpc1(0) if { status ge 300 } { status lt 400 } !http2 http-response track-sc0 var(txn.host) table BK_HTTPS_45 if { status ge 400 } { status lt 600 } !http2 http-response sc-inc-gpc0(0) if { status ge 400 } { status lt 500 } !http2 http-response sc-inc-gpc1(0) if { status ge 500 } { status lt 600 } !http2 http-response track-sc1 var(txn.host) table BK_HTTP2_23 if { status ge 200 } { status lt 400 } http2 http-response sc-inc-gpc0(1) if { status ge 200 } { status lt 300 } http2 http-response sc-inc-gpc1(1) if { status ge 300 } { status lt 400 } http2 http-response track-sc1 var(txn.host) table BK_HTTP2_45 if { status ge 400 } { status lt 600 } http2 http-response sc-inc-gpc0(1) if { status ge 400 } { status lt 500 } http2 http-response sc-inc-gpc1(1) if { status ge 500 } { status lt 600 } http2 default_backend BK_DEFAULTbackend BK_DEFAULT
server localhost 127.0.0.1:8080 check
backend BK_ALL
stick-table type string len 256 size 10k expire 7d store conn_cnt,sess_cnt,http_req_cnt,http_err_cnt,bytes_out_cntbackend BK_HTTP
stick-table type string len 256 size 10k expire 7d store conn_cnt,sess_cnt,http_req_cnt,http_err_cnt,bytes_out_cntbackend BK_HTTP_23
stick-table type string len 256 size 10k expire 7d store conn_cnt,gpc0,gpc1backend BK_HTTP_45
stick-table type string len 256 size 10k expire 7d store conn_cnt,gpc0,gpc1backend BK_HTTPS
stick-table type string len 256 size 10k expire 7d store conn_cnt,sess_cnt,http_req_cnt,http_err_cnt,bytes_out_cntbackend BK_HTTPS_23
stick-table type string len 256 size 10k expire 7d store conn_cnt,gpc0,gpc1backend BK_HTTPS_45
stick-table type string len 256 size 10k expire 7d store conn_cnt,gpc0,gpc1backend BK_HTTP2
stick-table type string len 256 size 10k expire 7d store conn_cnt,sess_cnt,http_req_cnt,http_err_cnt,bytes_out_cntbackend BK_HTTP2_23
stick-table type string len 256 size 10k expire 7d store conn_cnt,gpc0,gpc1backend BK_HTTP2_45
test
[root]# echo “show table BK_ALL” | socat /var/run/haproxy.stat1 stdio
# table: BK_ALL, type: string, size:10240, used:1
0x17e2688: key=test.com use=0 exp=604789122 conn_cnt=3 sess_cnt=0 http_req_cnt=3 http_err_cnt=0 bytes_out_cnt=636
[root]# echo “show table BK_HTTP” | socat /var/run/haproxy.stat1 stdio
# table: BK_HTTP, type: string, size:10240, used:1
0x17e2858: key=test.com use=0 exp=604784378 conn_cnt=3 sess_cnt=0 http_req_cnt=3 http_err_cnt=0 bytes_out_cnt=636
[root]# echo “show table BK_HTTP_23” | socat /var/run/haproxy.stat1 stdio
# table: BK_HTTP_23, type: string, size:10240, used:0
[root]# echo “show table BK_HTTP_45” | socat /var/run/haproxy.stat1 stdio
# table: BK_HTTP_45, type: string, size:10240, used:0
HAProxy version
haproxy -vv
HA-Proxy version 1.9.15 2020/04/02 - https://haproxy.org/
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_DL=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1Default settings :
maxconn = 2000, bufsize = 16384, maxrewrite = 1024, maxpollevents = 200Built with OpenSSL version : OpenSSL 1.1.1g 21 Apr 2020
Running on OpenSSL version : OpenSSL 1.1.1g 21 Apr 2020
Built without compression support (neither USE_ZLIB nor USE_SLZ are set).
Compression algorithms supported : identity(“identity”)
Built with multi-threading support.Available polling systems :
Total: 3 (3 usable), will use epoll.Available multiplexer protocols :
h2 : mode=HTX side=FE|BE
h2 : mode=HTTP side=FE
: mode=TCP|HTTP side=FE|BEAvailable filters :
