frontend fe_main
option http-use-htx
bind *:443 ssl crt /etc/hapee-1.8/certs/www.example.com.pem alpn h2,http/1.1
use_backend be_main
backend be_main
option http-use-htx
server server1 1.2.3.4:8080 proto h2
or
backend be_main
option http-use-htx
What is the difference between two backends?
when I try to call backend be_main using http2, I get 200 http2 200-OK for both cases.
(I have used ssl offload at the frontend as well)
For both cases, the server doesn’t have TLS(multiplexed HTTP1.1 and H2C server).
