Can we add cookies on http request instead of http response like below:
backend app-backend
option httpclose
server app1 10.89.1.10:80 check cookie app1 http-request add-header cookies SERVERID app1
server app2 10.89.1.20:80 check cookie app2 http-request add-header cookies SERVERID app2
Or
Can we add in URL Parameter in request if SERVERID is not present in URL like below
backend app-backend
option httpclose
server app1 10.89.1.10:80 check cookie app1 http-request set-uri https://%[req.hdr(Host)]%[path]?%[query]&SERVERID=app1 if SERVERID in URL NOT FOUND
server app2 10.89.1.20:80 check cookie app2 http-request set-uri http://%[req.hdr(Host)]%[path]?%[query]&SERVERID=app2 if SERVERID in URL NOT FOUND
Yes, understand that this is unique requirement, Here is the use case. It difficult to explain but still I will try to explain:
We have 2 application like manager and player
Manager => We can’t put Manager application under load balancing because it is still using java memory for managing session, this memory is not shared. Development team require more time implement this
Player => We plan to put Player application under load balancing. For authentication this player app send request to Manager application, if user is logged on Manager application then that user will be able to access player application. Multiple player applications which are under Load balancing can check user is authenticated by sending request to One Manager application. As there is only one Manager application then authentication should work fine, this was our expectation.
Here is the twist: Player send authentication request to Manager application and after that request Manager application also send another request for that particular player, but player is load balanced, so it doesn’t know which was that player who has originally send the request for authentication. We plan to add SERVERID in cookies or in URL, so that we can send the authentication request to that particular Player application which is under load balancing using haproxy acl urlp_sub. Development team will handle rest of the things.
Note : This authentication requests are generated directly from server not from user browser and Player authentication happen on first request, so I need the details on first request not in response
