I’ve created simplest pekko-http application in scala.
import org.apache.pekko.actor.ActorSystem
import org.apache.pekko.http.scaladsl.Http
import org.apache.pekko.http.scaladsl.server.Directives._
import org.apache.pekko.stream.Materializer
import scala.concurrent.ExecutionContextExecutor
object PekkoHttpServer extends App with LogFactoryTrait {
implicit val system: ActorSystem = ActorSystem("PekkoHttpServer")
implicit val materializer: Materializer = Materializer(system)
implicit val executionContext: ExecutionContextExecutor = system.dispatcher
val route =
path("hello") {
get {
complete("Hello, Pekko HTTP!")
Http().newServerAt("0.0.0.0", 8090).bind(route)
logger.info("Server online at http://0.0.0.0:8090/")
Then I’ve created its docker image using sbt-native-packager. And I’m running two servers using Ha Proxy.
haproxy/haproxy.cfg:
frontend http
bind *:8100
default_backend all
stats uri /stats
timeout client 10s
backend all
timeout connect 50s
timeout server 50s
option httpchk
server s1 pekko-ha-proxy-container-1:8090 check inter 5s fall 2 rise 2
server s2 pekko-ha-proxy-container-2:8090 check inter 5s fall 2 rise 2
docker-compose.yml:
version: "3"
services:
container_name: pekko-ha-proxy-container-1
image: pekko-ha-proxy:0.0.1
networks:
- my-network
container_name: pekko-ha-proxy-container-2
networks:
- my-network
haproxy:
image: haproxy:latest
ports:
- "8100:8100"
volumes:
- ./haproxy:/usr/local/etc/haproxy
networks:
- my-network
depends_on:
- pekko-ha-proxy-container-1
- pekko-ha-proxy-container-2
networks:
my-network:
external: true
When I run docker compose up and hit route http://localhost:8100/hello, it works perfectly fine.
Then I tried to simply run Ha Proxy Data Plane Api. For that:
1. I've downloaded haproxy using apt.
$ sudo apt install haproxy
2. Then downloaded Ha Proxy Data Plane Api.
$ wget https://github.com/haproxytech/dataplaneapi/releases/download/v3.0.3/dataplaneapi_3.0.3_linux_x86_64.tar.gz
3. Extracted it.
tar -zxvf dataplaneapi_3.0.3_linux_x86_64.tar.gz
4. Renamed the file `dataplaneapi.yml.dist` to `dataplaneapi.yml` and move it into my `haproxy` folder.
5. Changed the file paths to the HAProxy program and configuration file:
dataplaneapi.yml:
haproxy:
config_file: /usr/local/etc/haproxy/haproxy.cfg
haproxy_bin: /usr/local/sbin/haproxy
haproxy.cfg:
stats socket /var/run/haproxy.sock mode 660 level admin
master-worker
insecure-fork-wanted
userlist dataplaneapi
user admin insecure-password adminpwd
program api
command /usr/local/bin/dataplaneapi -f /etc/haproxy/dataplaneapi.yml
no option start-on-reload
docker-compose.yml:
version: "3"
services:
dataplaneapi:
image: haproxytech/haproxy-ubuntu
container_name: dataplaneapi
ports:
- "5555:5555"
volumes:
- ${PWD}/haproxy:/usr/local/etc/haproxy:rw
networks:
- ifkaar-network
networks:
ifkaar-network:
external: true
Now when I run docker compose up and run:
$ curl -X GET --user admin:adminpwd http://localhost:5555/v3/info
It is giving me:
{"api":{"build_date":"2024-08-23T15:38:09.000Z","version":"v3.0.3 1491b08a"},"system":{}}
Means it is also working fine. But I’m unable to combine both things. I want to add/remove my pekko-ha-http-container using Ha Proxy Data Plane Api. Guide me how can I do so? Do I only need dataplaneapi container or haproxy and dataplaneapi both containers?
