Basically I’m trying to get a new log format, to achieve this I need to capture some values from front end http request and response.
- For the log format I have added the HAPROXY_HEAD template to the Marathon config and its working fine
- I’m not really sure how to add the below captures to the front end which is for Port 80.
declare capture request len 24
http-request capture req.hdr(X-Request-Id) id 0
Capture the user id from header for logging
declare capture request len 36
http-request capture req.hdr(VDSID) id 1
Capture the ReqAppId from header for logging
http-request capture req.hdr(ReqAppId) id 2
Note : HAPROXY is running in a container and new services always append to the Front end automatically.
When I have tried to add the HAPROXY_HTTP_FRONTEND_HEAD, HAPROX_FRONTEND_HEAD templates but it created another front end for port 80 and services were failing sometimes.
So I want a solution that will append the captures to the existing frontend marathon_http_in??
Thanks for your help.
